03-11-2009, 15:27 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: THE END Age: 40
Member: 195225 Status: Offline Thanks Meter: 94 | help me 6300 7pin. ic 661u rm217 fcc id ppirm-217. im tested pinout 1 tx 2. *#0044# set language englesh |
03-11-2009, 22:47 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! start from testing system connector with multimeter: 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx if no such voltages- post PCB picture, maybe someone will recognise it |
plz help me 6300 no network | illu | Nokia Hardware & Hardware Repair | 4 | 05-02-2010 08:18 |
Help Me, 6300 "CONTACT SERVICE" with battery? | gsm_surya | Nokia Hardware & Hardware Repair | 14 | 02-22-2010 13:11 |
HELP ME!!!6300 with SecHash error on flash & erase | 22229999 | Universalbox | 4 | 02-19-2008 23:20 |
