11-27-2008, 14:24 | #1 (permalink) |
Freak Poster Join Date: Mar 2008 Location: Mombasa Age: 48
Member: 722683 Status: Offline Thanks Meter: 33 | cant format china fone module v2.69 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:CF68:B34E Connecting, wait... error: can't finalize test mode repeat operation and HOLD phone "Power" button long time ! error: operation failed ! Finished, time used: 102 sec Remove/Install battery now ! e what is this?please infinity help |
11-30-2008, 10:41 | #3 (permalink) |
Member: 722683 Status: Offline Thanks Meter: 33 | am not skiping anything,cant u see once i get the pinout by pinfinder and open infinity,the part that says press and hold is where the problem begins.it says connecting while i stil hold when says release thats when swos error.initially i used to do them well but since i downloaded the updates thats when this problem began.please help |
11-30-2008, 11:21 | #4 (permalink) |
Member: 722683 Status: Offline Thanks Meter: 33 | after changing the baudrate it manageCOM5 [VCP0] selected module v2.69 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" enhanced security fix enabled Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:CF68:B34E high speed disabled boot packet size: 0002 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud ... 230400 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:2AEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw 1: M220_PCB01_GPRS_MT6226_S01.K300_1_7.BIN ver. sw 2: K300_1.7, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: 01227E22202200:2AEA0000000000 checking area [00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: eeprom[M220_PCB01_GPRS_MT6226_S01.K300_1_7.BIN]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom[M220_PCB01_GPRS_MT6226_S01.K300_1_7.BIN]_20081130-131117.B0E.bin flash: 01227E22202200:2AEA0000000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Write Done Finalization ... formatting... flash: 01227E22202200:2AEA0000000000 Finalization Done Finished, time used: 312 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! s to format but phone fail to power on.this is the log |
formate and fone is dad pl help | shabbir_ghoniya | SpiderMan | 3 | 10-03-2008 12:04 |
plz hlp to format spreadtrum fone | peter002 | SpiderMan | 1 | 05-18-2008 08:42 |
China fone like X600 poss to unlock ? | Mr GsM | UST Pro II | 2 | 03-19-2007 06:55 |
Format ur fone without cables/pc/box | LBOZ_GSM | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 03-05-2007 09:31 |
