07-08-2009, 05:24 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: China/USA
Member: 718425 Status: Offline Thanks Meter: 5,872 | Can't Remove touchscreen calibration I am Allrady Work By InfinityBox touchscreen Repiar Mode : 1 COM18 [VCP1] selected module v2.84 Action: touchscreen calibration mode: 2 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E303:000D status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: R229A_HED_V00.03_20081113 Version: PHONE25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35044801123456 connection Ok detecting structure #5 (mode-2)... 0warning: wrong packet cs 1warning: wrong packet cs 2 3 done 210 byte(s) read reading data #2... writing data... verification... verification Ok Power-On and test phone now If calibration is not completed yet: 1. make "Reverse calibration order" Checked and try again 2. try another calibration mode Finished, time used: 11 sec Remove/Install battery now ! Mode : 2 COM18 [VCP1] selected module v2.84 Action: touchscreen calibration mode: 3 Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:E303:000D status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E05 Date: 2006.06.14 Version: 1.0 Version: R229A_HED_V00.03_20081113 Version: PHONE25_GEMINI_HW detecting structure #2... 5 11 done 67 byte(s) read imei: 35044801123456 connection Ok detecting structure #5 (mode-3)... 0 1 2 3 6 done 212 byte(s) read reading data #2... writing data... verification... verification Ok Power-On and test phone now If calibration is not completed yet: 1. make "Reverse calibration order" Checked and try again 2. try another calibration mode Finished, time used: 14 sec Remove/Install battery now ! What can i do |
07-08-2009, 05:42 | #2 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks Meter: 290 | Mate Screen caliboration have sevral mode try with all, if it is new firmware and havnt supported yet by Infinity Chinese Miricale you can upload the phone backup to Infinity support and they will support your phone in thier next update for solving urgently your problem just find a working phone with same firmware take its backup and flash to your phone. WBR |
07-08-2009, 06:37 | #4 (permalink) |
No Life Poster Join Date: May 2006 Location: Dhaka Age: 46
Member: 271880 Status: Offline Sonork: 100.1578866 Thanks Meter: 1,289 | you try mode-1,2,3 & check reverse calibration order. not succes? full formate & try again not success? flash your set 100% solv your problem. br, kabir telecom |
The Following User Says Thank You to kabirhossain For This Useful Post: |
07-08-2009, 08:28 | #7 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, If you are sure that you have used all calibration methods but still no luck - read full flash and send backup file to [email protected] with information about problem. Also include operation.log file in your mail. |
Bypass damaged Touchscreen calibration solution... | InfinitySupport | Infinity-Box | 223 | 10-28-2010 16:51 |
Chines Miracle N15 can't fix touchscreen calibration | Freshbol | Infinity-Box | 1 | 09-13-2008 19:32 |
Touchscreen calibration OK by MODE-2 | Chandreshswami | Infinity-Box | 4 | 08-02-2008 10:19 |
n82 I can not work Touchscreen Calibration | ahmedasmet | Infinity-Box | 4 | 06-25-2008 07:11 |
Bypass damaged Touchscreen calibration solution ( ChineseMiracle v2.45) | Ja\/\/aD | Service Products News & Updates | 0 | 05-25-2008 12:47 |
