07-13-2008, 13:35 | #1 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 383929 Status: Offline Thanks Meter: 10 | cant repair imei LG KE770 Ready Phone must be SWITCHED ON ! Connecting, wait... Connection Fail Finished i read the eeprom and whole flash, the phone boots ok so there is no problem with cable but when i write new imei the phone does not connect. Any suggestion. |
07-14-2008, 09:56 | #3 (permalink) |
Member: 383929 Status: Offline Thanks Meter: 10 | Although i have just purchased infinity + pinfinder but I am experienced box user i have checked all the possiblities i have checked with rj45 cable and even with pinfinder cable l18b used both in off set and on set but couldn't change the imei although the phone does boot ok and i read the whole 71mb flash and eeprom it was good with reading flash. any more suggestions. |
07-14-2008, 13:31 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Phone should be powered-on, it\'s no need to try it for this operation in powered-off state. Connect phone to cable, run software, press \"Write\" button and be sure that phone LCD is not black (phone is not in sleep mode), probably you need to press phone \"power\" button shortly to make phone LCD not black |
07-14-2008, 15:39 | #5 (permalink) | |
Member: 383929 Status: Offline Thanks Meter: 10 | Quote:
i have posted earlier that i have checked in both states of power on and power off used different cables rj45 one and pinfinder one both are good in reading flash and eeprom i have already repaired on lg kg200 imei so there is no error by me. The set does power on and shows insert sim as the program said "Phone should be on" but it could not be detected by the software. thats all information i got. Thanks for the quick reply. I never i got such a faster reply from any of the support team. | |
08-05-2008, 08:51 | #7 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | Same issue with me Quote:
using pinfinder, TESTED (not working) using Real Direct Cable (Not working) Flashing is being properly but imei repair dose not work .. | |
01-28-2009, 15:57 | #10 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Faisalabad, Pakistan Age: 41
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | I am also having same problem and using latest 1.61 version. infinity team has not solved this problem yet. Over 5 month now still not fix imei repair bug. if anyone success repair imei than plz post here with detail? Kind regards, Vicky |
01-28-2009, 20:34 | #12 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | I want to change IMEI coz current is not working message show "rejected by network" but phone is not connect. read of flash and other operation which not required powered on phone is working but IMEI change and read general information is not work coz it required powered on phone and phone already powered on and also avoide standby mode by pressing power or other key but still not connect. So that plz fix it as soon as possible. Waiting for your kind response. Kind regards, Vicky |
M7600 - Cant repair IMEI - Cant read Security data | marquesphelder | Z3X-Team Products | 9 | 08-06-2010 07:14 |
6288 cant repair IMEI with RPL!!!!!!!!! | GSMLover2010 | MT-BOX | 6 | 09-26-2007 05:23 |
cant repair imei e490 with nspro | hossein1155 | NSPRO | 4 | 07-29-2007 13:12 |
cant repair IMEI on Z510 | nickvanexel | NSPRO | 1 | 08-22-2006 10:02 |
Swap cant repair IMEI after full flash CX65 | Albinas | SWAP | 0 | 11-27-2005 19:07 |
