Old 05-04-2017, 16:02   #1 (permalink)
Member: 88864
Thanks Meter: 10
Cant repair imei "none"
mtk device with both imeis |none|.
identify ok,also can unlock and other functions work fine but when try to repair security,phone is detected but after software asks for reconect cable phone detects and starts to turn on and hangs...
log
Operation : Repair Security [ v1.58 ]
Wait for phone...
Phone found! [ 37 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A2058494E594816A1A22212A067
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , HYNIX
[eMMC] : FLASH_CID : 90014A2058494E594816A1A22212A067
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0x7E1653ED708823EF8400612EB0295187
INT RAM : 0x00020000
EXT RAM : 0x20000000 [512 MiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
IMEI [00] : 35508xxxxxxxxxxx
IMEI [01] : 35508xxxxxxxxxxx
Set IMEI [00] : 3550xxxxxxxxx
Set IMEI [01] : 3550xxxxxxxxx
Prepare finished. Security check required!
Wait for phone...
Phone found! [ 37 ]
Sync...
Old 05-04-2017, 16:49   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 14,637
For start need repair baseband.
The Following User Says Thank You to JayDi For This Useful Post:
Old 05-05-2017, 08:22   #3 (permalink)
Member: 88864
Thanks Meter: 10
ive done that
done "fix unknown baseband" but still same...
maybe for fixing baseband there is other procedure?
also cant make "modem reinit"-phone goes on or starts charging
Old 05-09-2017, 09:23   #4 (permalink)
Member: 88864
Thanks Meter: 10
any ideas..
cant figure out this
Old 05-09-2017, 09:33   #5 (permalink)
Member: 579725
Sonork: 100.1675677
Thanks Meter: 61
once the software is hang after that some times imei is alrady writen ... i hapen with me even software says error but imei is done
Old 05-11-2017, 10:03   #6 (permalink)
Member: 88864
Thanks Meter: 10
where is infinity support
still waiting for some help..
Old 05-11-2017, 10:22   #7 (permalink)
JayDi's Avatar
Member: 462970
Does "baseband version" exists in "settings - about"?
Old 05-12-2017, 10:05   #8 (permalink)
Member: 88864
Thanks Meter: 10
yes,baseband version present.
moly wr8.w1315.md.wg.mp.v36
Old 05-12-2017, 13:14   #9 (permalink)
JayDi's Avatar
Member: 462970
Good. Now you need read info with all options enabled. Inside you can find modem version. Find NVRAM according it and write. Make factory reset and check result after.
Old 05-15-2017, 14:01   #10 (permalink)
Member: 88864
Thanks Meter: 10
MODEM : mbk72_w_kk_hspa,where can i faund nvram?
phone:landrover discovery v8
Old 05-15-2017, 15:05   #11 (permalink)
JayDi's Avatar
Member: 462970
Wrong. Post complete log.
Old 05-15-2017, 16:18   #12 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,227
try this one.
MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_1_wg_n_eMMC
Wait for phone...
Phone found! [ 191 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01
eMMC Flash : 90014A2058494E594816A1A21F34A0CB
[eMMC] : FLASH_CID : 90014A2058494E594816A1A21F34A0CB
DEV RID : 0xDA47F7C46635A4002254FFAFB664A99A
SOC VERIFY : C1
Boot Ok!
[AP] : Initial info read Ok!
Brand : V8
ProdName : V8
ProdModel : V8
Device : V8
AndroidVer: 4.4.2
MTKxCPU : MT6572
MTKxPRJ : ALPS.KK1.MP7.V1.7
SECURITY :
IMEI_SW [1] : 358885050076472
IMEI_SW [2] : 358885050076480
BTMAC Addr : 000046657201
WiFi MAC : 000000000000
MODEM :
BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V36_1_wg_n
EXTRA :
LCD [0] : nt35510_dsi_cmd_6572
LCD Res : 800x480
TOUCH [0] : ft5316
TOUCH [1] : #GT9XX_hotknot
CAM [0] : gc0329_yuv
CAM [1] : sp2519_yuv
LOCALE : en_US zh_CN zh_TW hr_HR da_DK ja_JP pl_PL sr_RS sv_SE ca_ES lv_LV lt_LT nb_NO sk_SK sl_SI bg_BG uk_UA fi_FI et_EE hy_AM kk_KZ ar_IL ar_EG nl_NL nl_BE en_AU en_CA en_IN en_IE en_NZ en_SG en_ZA en_GB fr_FR fr_BE fr_CA fr_CH de_DE de_LI de_AT de_CH it_IT it_CH pt_BR pt_PT es_ES bn_IN cs_CZ el_GR he_IL iw_IL hi_IN hu_HU in_ID ko_KR ms_MY fa_IR ro_RO ru_RU th_TH tr_TR ur_PK vi_VN tl_PH my_MM km_KH am_ET be_BY sw_TZ zu_ZA
Done!
Page generated in 0.39051 seconds with 7 queries
