04-07-2008, 13:55 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 46
Member: 122869 Status: Offline Thanks Meter: 11 | Cant repair one unsuported no name phone tryed with many similar flashes from support but cant find good flash. any advice???????? Here is log: OM10 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: repair security area Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:E7C1:C5E6 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.19FDA335.[B04_MASTER_PL_N_JB_PCB01_GPRS_MT6226_S01.MAUI_05C_ W06_16_MP.BIN_9FF8C877].rpl New firmware detected: B04_MASTER_PL_N_JB_PCB01_GPRS_MT6226_S01.MAUI_05C_ W06_16_MP.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) identification#1 detection finished device-id: 19FDA335 identification#1 protocol ver: 04 ver. sw1: B04_MASTER_PL_N_JB_PCB01_GPRS_MT6226_S01.MAUI_05C_ W06_16_MP.BIN ver. sw2: MAUI.05C.W06.16.MP, 88370760 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: 01227E22202200:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _19FDA335_B04_MASTER_PL_N_JB_PCB01_GPRS_MT6226_S01 .MAUI_05C_W06_16_MP.BIN_9FF8C877_20080407-143050.B0X.bin Finished, time used: 140 sec Remove/Install battery now ! http://rapidshare.com/files/10556463...407-12391.html |
04-07-2008, 15:03 | #3 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | its a new firmware, the best and it might be the only way [if u did not find it on support] is to get a another phone with same firmware [which will be hard in most cases] and read from the working one and write to the damaged one. did u try to format the phone? BR Mansi |
04-08-2008, 11:22 | #6 (permalink) |
Member: 122869 Status: Offline Thanks Meter: 11 | Here it is again my friend: http://rapidshare.com/files/10580770...model.rar.html |
04-15-2008, 20:44 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i think you must find same working phone, read out backup and use it for rescue your phone. In next chinese miracle software this version will be supported (will not give "new firmware detected" warning) so you will be able to flash it without problems |
No ! Cant repair IMEI 123456...with RPL Service !! | fingusio | Genie Universal | 4 | 02-04-2010 16:44 |
Any one ever seen this phone named DORADO? | .:==di@bila==:. | Various | 14 | 10-12-2008 11:35 |
Cant repair this unsuported type of 8600 luna | AKKA | Infinity-Box | 1 | 05-07-2008 19:03 |
