Old 03-21-2016, 21:36   #1 (permalink)
.::GEANECIV::.'s Avatar
Member: 853097
Sonork: 100.1622287
Thanks Meter: 131
Can't Reset FRP Asus Z00VD MT6580
Hi team, please support reset frp for locked bootloader.
I realy need this solution
I try to unlock bootloader via fastboot mode but always failed, maybe not checked allow oem unlock on setting
I hope and I believe infinity team can support in next update
Thank You
The Following User Says Thank You to .::GEANECIV::. For This Useful Post:
Old 03-28-2016, 09:41   #2 (permalink)
Member: 447517
Thanks Meter: 22
have this problem to.. hope infinity release solution..
Old 03-28-2016, 10:04   #3 (permalink)
Member: 447517
Thanks Meter: 22
Wait for phone...
Phone found! [ 132 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BB_CPU_NME : [MediaTek] MT6580_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x94
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A483847316505075B94C9CF5233
Initialize Memory ...
DRAM configured from IDB!
DRAM initialize passed!
DRAM size : 0x08000000
[DA_ERROR] : DA Load failed!
ErroCode : 0x2008
DA_LOAD_FAILED
Boot Error!
Operation Failed
Elapsed: 00:00:23
Reconnect Power/Cable!
Old 06-25-2016, 10:29   #4 (permalink)
Teknotel-GSM's Avatar
Member: 917368
Sonork: 1615575
Thanks Meter: 147
I have problem too...
what is solution ???
Old 07-25-2016, 11:12   #5 (permalink)
Member: 683463
Thanks Meter: 188
got also same problem help how to solve mt6580 chipset asus frp lock
Old 07-25-2016, 11:36   #6 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
ASUS secured support planned in some of near version. I got all samples and work on them.
The Following User Says Thank You to JayDi For This Useful Post:
Old 07-25-2016, 13:36   #7 (permalink)
WINDA's Avatar
Member: 804772
Thanks Meter: 129
dont just replay
do you have tutorial .. my phone dead after read now dead
Old 07-22-2017, 14:42   #8 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
hey..
infinty can read the fw.. frp is supported or not..? i just wanted to ask before frp action..
Old 07-22-2017, 14:45   #9 (permalink)
JayDi's Avatar
Member: 462970
Make JUST frp reset.
Old 07-22-2017, 14:51   #10 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
[QUOTE=JayDi;12604433]Make JUST frp reset.
it is done thanx.. booting with vol down...
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 46 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer   : 0x0005
BLVersion : 0x00FE
Processing DA stage
eMMC Flash : 90014A484147326505078DD19D2732BF
DRAM size : 0x40000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A484147326505078DD19D2732BF
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID    : 0x46E20CEA4F0F5F235F71E3306D4F2B80
INT RAM    : 0x00020000
EXT RAM    : 0x40000000 [1 GiB]
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:24
The Following 3 Users Say Thank You to LoveLess For This Useful Post:
Old 07-25-2017, 09:44   #11 (permalink)
SR9
SR9's Avatar
Member: 957066
Sonork: 100.1658197
Thanks Meter: 642
same problem here
Wait for phone...
Phone found! [ 93 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:04
The Following User Says Thank You to SR9 For This Useful Post:
Old 07-25-2017, 11:35   #12 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
same problem here
Wait for phone...
Phone found! [ 93 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6580
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:04
Many MTK6580,MT6755,MT5735 Same Problem shw .....
But His Also Support Others boxes. Like Miracle.Inferno ETC.........
The Following User Says Thank You to >>Gsmmilon>> For This Useful Post:
Page generated in 0.19983 seconds with 9 queries
