04-04-2017, 10:29 | #1 (permalink) |
Freak Poster Join Date: May 2015 Location: on earth
Member: 2387421 Status: Offline Sonork: 100.1668425 Thanks Meter: 71 | cant reset oppo r9s plus screen lock Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.11 Operation : Reset UserLocks [ v1.11 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 652 [MSM8952] ID_BLOCK_S : 482E670D ID_BLOCK_I : 009900E1 ID_BLOCK_L : 6DB223FE0CCACDE65F67F288B2FAC228 ID_BLOCK_L : 99D33597C88B5D86E4183F8AD6943737 Use CM2 Internal Loader Loader Sent! Initializing ... Error : FH Configuration failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
04-04-2017, 12:28 | #2 (permalink) |
Registered User Join Date: Sep 2009 Location: Philippines
Member: 1129019 Status: Offline Sonork: first aider Thanks Meter: 19 | MRT Dongle can reset it but dont try ,i have mine after success reset software says ,your phone will hang on logo ,you cant even reset in recovery .it will gives you an error link here http://forum.gsmhosting.com/vbb/f100...eeded-2210356/ |
10-08-2017, 12:37 | #4 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Bangladesh Age: 34
Member: 2581716 Status: Offline Sonork: 30294069 Thanks Meter: 137 | Hi 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 625 [MSM8953] ID_BLOCK_S : 4C81AF78 ID_BLOCK_I : 000460E1 ID_BLOCK_L : 5140F00A5739A6CDE88E0F72C9A036F9 ID_BLOCK_L : 90D5A94F34471A022B4AB20C3954F0A2 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8953 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000E8F800000 [ eMMC 64 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Storage : MFR : 0x15 , VENDOR : SAMSUNG , NAME : RC14MB Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:12 Reconnect Power/Cable! |
10-08-2017, 16:04 | #5 (permalink) | |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,127 | Quote:
