07-16-2006, 18:54 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: Jamaica
Member: 28559 Status: Offline Thanks Meter: 85 | can't unlock c139 tracfone |
07-16-2006, 19:41 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hi, Could you, please, explain the phone status after flashing with ordinary firmware ? To be honest I am not so experienced and for about that 10 years that I am in mobile phone repair field I still can't understand the meaning of word "dead". 1. Is it totally dead ? 2. Is it partially dead ? 3. Is it not dead but alive but only LCD in black color ? 4. Is it not dead but alive but only LCD in white color ? .... 999. reason number 999 Also, please, read eeprom and send it to me: [email protected] (please, only eeprom, not full flash). |
07-16-2006, 21:41 | #3 (permalink) |
Member: 28559 Status: Offline Thanks Meter: 85 | dead means in this case, phone can't power on no, lights on keypad no lights on display and no sound. phone can be successfully flashed by infinity with any c139 flash but 'dead' with ordinary firmware. alive with tracfone flash. when flashed with tracfone flash phone is alive but locked. this is the first time i am having problems with c139 from tracfone. i have unlocked them before without any problems. |
07-16-2006, 22:06 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | It looks like problem like with latest V170/171 with LCD problems. Can't give any good advice about unlocking right now. Pls, read eeprom and send to [email protected] Also, what method you used for TracFone C139 unlock before ? Only read code/direct unlock or you flashed phone with ordinary firmware ? |
07-16-2006, 22:29 | #5 (permalink) |
Member: 28559 Status: Offline Thanks Meter: 85 | i flashed phone with the files below to unlock c139 from tracfone before this last one. i have already given back phone to client but i have automatic eeprom backup . C139_0[1].0.6_Main.31M C139_0[1].0.6_Flex_DF_00T.31F C139_0[1].0.6_LP_T8b_002_En_Hu_Pl.31 Last edited by gorgans; 07-16-2006 at 22:53. |
07-22-2006, 11:19 | #6 (permalink) |
No Life Poster Join Date: Nov 2002 Location: La Paz Age: 53
Member: 17431 Status: Offline Thanks Meter: 22 | Also C139 Tracfone first I direct unlock then done but still lock any solution? Heres the log. Action: Unlock Device: C139 Checking data, wait... Connect... Press and HOLD Power button... Release Power button ! Connect Done Boot... Boot Done Set Baud... 115200 Set Baud Done Check Flash-1... SW Ver: 8.5.17 HW Ver: MOTOROLA_E88 Check Flash-1 Done Check Flash-2... In progress... File saved: Backup_eeprom-1__2006-7-22_17-46-8.31E.bin Check Flash-2 Done Write... Write Done Finished Remove/Install battery now ! Time used: 51 sec Br, Logoman |
01-22-2007, 06:19 | #10 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
try to use other flash files set, also check phone hardware (probably LCD damaged if phone was in this condition when you got it). | |
04-12-2008, 07:26 | #11 (permalink) |
Junior Member Join Date: Apr 2008
Member: 748006 Status: Offline Sonork: vicgero Thanks Meter: 0 | hi mr infinity , i have a c139 trackfone v. 9.2.17 and i want to know if infinity box can flash this version, i tried but i couldnt, i want to erase the banner and flash it and unlock please help me, thanks |
04-12-2008, 10:39 | #12 (permalink) | |
If you can't flash phone ordinary way you can use this method: C:\Program Files\InfinityBox\Documentation\Infinity-Box_How_to_unlock_Moto-C139_TracFone-8.8.17_C113-C118-C123_2.2.83_and_newest.htm | |
*help* Can't flash c139 tracfone *urgent* | DBXBOX | Motorola ODM | 1 | 09-22-2008 12:58 |
unlock c139 tracfone ! | juwanapati | Infinity-Box | 2 | 07-15-2008 05:48 |
how to unlock motorala c139 tracfone!!!! | Almario | TotalMoto | 4 | 06-16-2007 11:50 |
Unlock C139 Tracfone | Lhick | Smart-Clip | 9 | 04-17-2007 12:46 |
c139 tracfone already unlocked but no signal | cora | Infinity-Box | 1 | 10-17-2006 06:15 |
