Cant Unlock J110i With Infinity. CANT UNLOCK J110 I WITH INFINITY IT SHOWS UNLOCK DONE BUT NOT UNLOCK PHONE .ITS 4LOCK CLOSED. COM8 [VCP0] selected Device: Sony-Ericsson J110i Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 039C-000 HW ver: KIM-5- Check Flash Done Check Parameters... file saved: backup_eeprom_calibration_20070925-170335.6AE.bin Check Parameters Done Check Space... Flash: 0089:886200010001 flash: Intel 28F320W18-T T 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Writing Done Finished, time used: 29 sec Remove/Install battery now ! |
Some people have unlocked succesfuly and some have not we are working on a solution where every one can unlock |
hi, use Polar Box 2 first then use inifinity box--------------------------work 100% i had unlock more than 20 Cell phone........................some you have to do many time. good luck |
Yesterday i try to unlock but not success please support asap. |
hic me too, yesterday i try to unlock .. unlock done but when put simcard ...... lock yet |
by me the same i tryied to unlock one SE J110i unlock write done !! but no sucsses :S:S infinity team c'mon one new update |
COM14 [VCP1] selected Device: Sony-Ericsson J110i Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... 406250 Set Baud Done Check Flash... SW ver: 039C-000 HW ver: KIM-5- Check Flash Done Check Parameters... file saved: backup_eeprom_calibration_20071002-115758.6AE.bin Check Parameters Done Check Space... Flash: 0089:886200010001 flash: Intel 28F320W18-T T 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Writing Done Finished, time used: 24 sec Remove/Install battery now ! But the phone is still locked :(( |
when ready new soft for unlock j110i ????? |
Hi, please fix bag, i have j110 O2 prepade Germany, I cannot unlock phone. here is log, phone still locked COM6 [VCP2] selected Device: Sony-Ericsson J110i Checking data, wait... Action: unlock Boot... Phone should be Switched OFF ! Press Power button now ! Connecting... Boot Done Check Connection... Check Connection Done Set Baud... Set Baud Done Check Flash... SW ver: 039C-000 HW ver: KIM-5- Check Flash Done Check Parameters... file saved: backup_eeprom_calibration_20071003-002613.6AE.bin Check Parameters Done Check Space... Flash: 0089:886200010001 flash: Intel 28F320W18-T T 4Mb Check Space Done Check Data... Check Data Done Erasing... erase operation not required Erasing Done Writing... Writing Done Finished, time used: 32 sec Remove/Install battery now ! |
tested i hope that infinty team can fix this bugg..why not add mot F3 ??????..direct unlock thanks |
But soft says "wrong model choosen" ? |
same problem, j110 not unlocked whit my infinity. use rockerdongle, 100% working. |
i also tried but fail hope we got soon !! BR Faisal_Computer |
maybe with flashing from files from infinity support will unlock it? |
@mrfixit flashing can't help @all Dear Friends, As you all know, our solution for J110/J120 unlock released in test condition. Thank you very much for your test reports ! We continue our work so, please, be little bit patient and don't create again threads about test software. Thank you for understanding and cooperation ! |
