Can't Unlock Nexian NX G700 Here is log : COM5 [VCP3] selected module v2.84 Action: read codes unlock method: read codes Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:AA21:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E201B_FM_PR1_IN_V0.7 Version: TINNO23C_08A_GEMINI_HW detecting structure #2... 1 2 3 5 7 8 9 11 13 done 80 byte(s) read imei: 35332703064288 connection Ok detecting structure #1... 0 2 3 4 7 8 9 13 14 15 16 18 19 20 23 24 25 29 30 31error: detection failed (20 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 13 sec Remove/Install battery now ! Here is backup file : http://www.megaupload.com/?d=BF838K2R thanks |
Hello, Did you tried other unlock methods ? |
Another try : Unlock method : standard COM5 [VCP1] selected module v2.85 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:AA21:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation ==================== New firmware detected (v.2.85, database date: 20.07.2009): TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E201B_F M_PR1_IN_V0_7.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E201B_F M_PR1_IN_V0_7.BIN ver. sw 2: E201B_FM_PR1_IN_V0.7, 00000000 ffs offset/size: 00E00000/001F8000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting security area (code #2)... .................................................. .................................................. .................................................. .................................................. .................................................. ...... security area (code #2) is absent detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom structure pass 1... ........................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... ....................................... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E201B_F M_PR1_IN_V0_7__ffs... file saved: D:\Program Files\InfinityBox\ChineseMiracle\TINNO23C_08A_GEMI NI_PCB01_GPRS_MT6223P_S00.E201B_FM_PR1_IN_V0_7__ff s_20090723-144611.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed Patch required data Done Special operation ... Special operation Done Write ... flash: 2088C4FFFFFFFF:2088C400000000 Write: eeprom error: no any expected answer error: flash write error: 00E40000:00002000 error: no any expected answer error: flash write error: 00E40000:00002000 error: no any expected answer error: flash write error: 00E40000:00002000 error: no any expected answer error: flash write error: 00E40000:00002000 Write Fail Finished, time used: 341 sec Remove/Install battery now ! Unlock method : smart fast COM5 [VCP1] selected module v2.85 Action: unlock unlock method: smart fast Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:AA21:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E201B_FM_PR1_IN_V0.7 Version: TINNO23C_08A_GEMINI_HW detecting structure #2... 1 2 3 5warning: wrong packet cs 7 8 9 11 13 done 80 byte(s) read imei: 35332703064288 connection Ok detecting structure #1... 0 2 3 4 7 8 9 13 14 15 16 18 19 20 23 24 25 29 30 31error: detection failed (19 tries), read flash and send to support error: can't read required data error: operation failed ! Finished, time used: 17 sec Remove/Install battery now ! Still no luck, hope Infinity Support will release another update for this type ... thanks |
Hello, Thanks for reports ! We will try to add this model ASAP. You have full flash backup, so you can try to make this: 1. make "format ffs" 2. restore imei What is the results ? Also, what code phone ask when you power-on phone with sim card ? |
Hello, The phone not ask for code, just want to unlock it coz phone SIM 1 is locked to EXCELCOMINDO . thanks for reply |
Hello, What is this provider MCC/MNC ? |
Hello, MCC : 510 MNC : 11 Brand : XL thanks |
Hello, Please, use this new test software: http://www.infinity-box.com/download...dule_v2.83.rar Please, try to unlock phone by different unlock methods, let's see results. |
Hello, Same result ... Unlock method : standard COM5 [VCP0] selected module v2.83 Device: Nexian-NX-G700 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AA21:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E201B_F M_PR1_IN_V0_7.BIN ver. sw 2: E201B_FM_PR1_IN_V0.7, 00000000 ffs offset/size: 00E00000/001F8000 ffs address assigned: 00E00000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Nexian-NX-G700_TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E2 01B_FM_PR1_IN_V0_7__ffs... file saved: D:\Program Files\InfinityBox\MModule\Nexian-NX-G700_TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E2 01B_FM_PR1_IN_V0_7__ffs_20090728-131325.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done Special operation ... detecting parameters to apply patch area 0/... ..... flash: 2088C4FFFFFFFF:2088C400000000 flash: 2088C4FFFFFFFF:2088C400000000 Write: area 0/1 error: no any expected answer error: flash write error: 00140000:00002000 error: no any expected answer error: flash write error: 00140000:00002000 error: can't write required area error: area 0/ can not apply patch Special operation Done Write ... error: no any expected answer error: no any expected answer : wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer : wrong answer after chip cfi request error: no any expected answer error: no any expected answer : wrong answer after chip id request Write Fail Finished, time used: 416 sec Remove/Install battery now ! Unlock method : smart fast COM5 [VCP0] selected module v2.83 Action: unlock unlock method: smart fast Model: Nexian-NX-G700 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AA21:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E201B_FM_PR1_IN_V0.7 Version: TINNO23C_08A_GEMINI_HW 80 byte(s) read imei: 35332703064288 connection Ok 186 byte(s) read reading data... reading data #2... reading data #4... reading data #5... WARNING ! Unknown lock structure ! Read flash and send to support: [email protected] error: operation failed ! Finished, time used: 32 sec Remove/Install battery now ! unlock method : read codes COM5 [VCP0] selected module v2.83 Action: read codes unlock method: read codes Model: Nexian-NX-G700 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AA21:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E201B_FM_PR1_IN_V0.7 Version: TINNO23C_08A_GEMINI_HW 80 byte(s) read imei: 35332703064288 connection Ok 186 byte(s) read reading data #4... reading data #5... error: source data size is less than expected error: operation failed ! Finished, time used: 10 sec Remove/Install battery now ! unlock method : standard fast COM5 [VCP0] selected module v2.83 Device: Nexian-NX-G700 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AA21:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E201B_F M_PR1_IN_V0_7.BIN ver. sw 2: E201B_FM_PR1_IN_V0.7, 00000000 ffs offset/size: 00E00000/001F8000 ffs address assigned: 00E00000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data ... ....................................... lock area found ....................................... lock area found Patch required data Done Special operation ... detecting parameters to apply patch area 0/... ..... flash: 2088C4FFFFFFFF:2088C400000000 flash: 2088C4FFFFFFFF:2088C400000000 Write: area 0/1 error: no any expected answer error: flash write error: 00140000:00002000 error: no any expected answer error: flash write error: 00140000:00002000 error: can't write required area error: area 0/ can not apply patch Special operation Done Write ... error: no any expected answer error: no any expected answer : wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer : wrong answer after chip cfi request error: no any expected answer error: no any expected answer : wrong answer after chip id request error: can't detect chip at required chip base error: no any expected answer error: no any expected answer : wrong answer after chip id request error: no any expected answer error: no any expected answer error: no any expected answer : wrong answer after chip cfi request error: no any expected answer error: no any expected answer : wrong answer after chip id request error: can't detect chip at required chip base Write Fail Finished, time used: 293 sec Remove/Install battery now ! thanks |
more than 7days & still waiting,.. when infinity support release solution for it.... ???? thx :) |
Yes, I am also surprised that this time Infinity-Box has such delay due to ordinary Infinity-Box need only 1 (one) day to prepare new solution. I think that this kind of delay means that new update will be for models that is not so easy to unlock. Btw, do you know the difference in "press big unlock button and unlock phone with Infinity-Box in several seconds" and "create new solution" ? |
"MModule" v2.83 released, please try to use it: http://forum.gsmhosting.com/vbb/showthread.php?t=799956 |
Hello, Try today : Standard methode : COM5 [VCP1] selected module v2.83 Device: Nexian-NX-G700 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AA21:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 921600 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 detection finished identification#1 protocol ver: 05 ver. sw 1: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E201B_F M_PR1_IN_V0_7.BIN ver. sw 2: E201B_FM_PR1_IN_V0.7, 00000000 ffs offset/size: 00E00000/001F8000 ffs address assigned: 00E00000 detect device identification#2... detection phase #1... . detect device identification#2 finished sim-lock status: unknown Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Nexian-NX-G700_TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E2 01B_FM_PR1_IN_V0_7__ffs... file saved: D:\Program Files\InfinityBox\MModule\Nexian-NX-G700_TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E2 01B_FM_PR1_IN_V0_7__ffs_20090805-193932.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done Special operation ... detecting parameters to apply patch area 0/... ..... flash: 2088C4FFFFFFFF:2088C400000000 flash: 2088C4FFFFFFFF:2088C400000000 Write: area 0/1 .................................................. ......... area 0/ patch applied Ok Special operation Done Write ... flash: 2088C4FFFFFFFF:2088C400000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 184 sec Remove/Install battery now ! OK, but phone still locked ... Smart Fast methode : COM5 [VCP1] selected module v2.83 Action: unlock unlock method: smart fast Model: Nexian-NX-G700 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AA21:000C status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6223,E05 Date: 2000.00.00 Version: 1.0 Version: E201B_FM_PR1_IN_V0.7 Version: TINNO23C_08A_GEMINI_HW 80 byte(s) read imei: 35332703064288 connection Ok 186 byte(s) read reading data... reading data #2... reading data #4... reading data #5... WARNING ! Unknown lock structure ! Read flash and send to support: [email protected] error: operation failed ! Finished, time used: 11 sec Remove/Install battery now ! thanks |
Hello, Standard Methode : COM18 [VCP2] selected module v2.84 Device: Nexian-NX-G700 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AA21:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 05 ver. sw 1: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E201B_F M_PR1_IN_V0_7.BIN ver. sw 2: E201B_FM_PR1_IN_V0.7, 00000000 ffs offset/size: 00E00000/001F8000 ffs address assigned: 00E00000 detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: Nexian-NX-G700_TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E2 01B_FM_PR1_IN_V0_7__ffs... file saved: D:\Program Files\InfinityBox\MModule\Nexian-NX-G700_TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E2 01B_FM_PR1_IN_V0_7__ffs_20090822-153915.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done Special operation ... detecting parameters to apply patch area 0... .................................................. .............. error: area 0 can not apply patch Special operation Done Write ... flash: 2088C4FFFFFFFF:2088C400000000 Write: eeprom Write Done Finalization ... Finalization Done Finished, time used: 148 sec Remove/Install battery now ! Still locked Standard Fast methode : COM18 [VCP4] selected module v2.84 Device: Nexian-NX-G700 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard fast Unlock procedure can be faster if you skip ffs/eeprom area backup procedure. Do you want to disable ffs/eeprom backup ? ffs/eeprom backup disabled Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:AA21:000C status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 05 ver. sw 1: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E201B_F M_PR1_IN_V0_7.BIN ver. sw 2: E201B_FM_PR1_IN_V0.7, 00000000 ffs offset/size: 00E00000/001F8000 ffs address assigned: 00E00000 detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data ... ....................................... lock area found ....................................... lock area found Patch required data Done Special operation ... detecting parameters to apply patch area 0... .................................................. .............. error: area 0 can not apply patch Special operation Done Write ... flash: 2088C4FFFFFFFF:2088C400000000 flash: 2088C4FFFFFFFF:2088C400000000 Write: lock-area-1 flash: 2088C4FFFFFFFF:2088C400000000 flash: 2088C4FFFFFFFF:2088C400000000 Write: lock-area-4 Write Done Finalization ... Finalization Done Finished, time used: 71 sec Remove/Install battery now ! Still locked Using smart fast give " Range Check Error" thanks |
Hello, We hope to release new software with updated unlock method for this model ASAP. |
