Old 07-22-2009, 07:11   #1 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
Can't Unlock Nexian NX G700
Here is log :
COM5 [VCP3] selected
module v2.84
Action: read codes
unlock method: read codes
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:AA21:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: E201B_FM_PR1_IN_V0.7
Version: TINNO23C_08A_GEMINI_HW
detecting structure #2...
1 2 3 5 7 8 9 11 13 done
80 byte(s) read
imei: 35332703064288
connection Ok
detecting structure #1...
0 2 3 4 7 8 9 13 14 15 16 18 19 20 23 24 25 29 30 31error: detection failed (20 tries), read flash and send to support
error: can't read required data
error: operation failed !
Finished, time used: 13 sec
Remove/Install battery now !
Here is backup file : http://www.megaupload.com/?d=BF838K2R
thanks
The Following User Says Thank You to Edocomsel For This Useful Post:
Old 07-22-2009, 17:37   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,206
Hello,
Did you tried other unlock methods ?
Old 07-23-2009, 09:02   #3 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
Another try :
Unlock method : standard
COM5 [VCP1] selected
module v2.85
Device: Autodetect 6205-6227 NOR
Action: "sp-unlock"
unlock method: standard
ffs/eeprom backup enabled, it may takes several minutes !
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
boot packet size: 0400
Boot Done
Initialize ...
flash: 2088C4FFFFFFFF:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
460800
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
New firmware detected (v.2.85, database date: 20.07.2009):
TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E201B_F M_PR1_IN_V0_7.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
identification#1 protocol ver: 05
ver. sw 1: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E201B_F M_PR1_IN_V0_7.BIN
ver. sw 2: E201B_FM_PR1_IN_V0.7, 00000000
ffs offset/size: 00E00000/001F8000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting security area (code #2)...
security area (code #2) is absent
detect device identification#2...
detect device identification#2 finished
detecting ffs/eeprom structure pass 1...
detect standard fat location pass #1...
detect extended fat location pass #1...
detect standard fat offset pass #1...
detect standard fat data...
fat layout detection complete
ffs/eeprom detected ok: element #1
Check firmware integrity Done
Check firmware content ...
Check firmware content Done
Backup required data ...
reading: TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E201B_F M_PR1_IN_V0_7__ffs...
file saved: D:\Program Files\InfinityBox\ChineseMiracle\TINNO23C_08A_GEMI NI_PCB01_GPRS_MT6223P_S00.E201B_FM_PR1_IN_V0_7__ff s_20090723-144611.B0E.bin
Backup required data Done
Patch required data ...
detection procedure, wait...
detection procedure completed
Patch required data Done
Special operation ...
Special operation Done
Write ...
Write: eeprom
error: no any expected answer
error: flash write error: 00E40000:00002000
Write Fail
Finished, time used: 341 sec
Unlock method : smart fast
module v2.85
Action: unlock
unlock method: smart fast
19200 autodetect
CPU: MT6223
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
1 2 3 5warning: wrong packet cs
7 8 9 11 13 done
80 byte(s) read
connection Ok
0 2 3 4 7 8 9 13 14 15 16 18 19 20 23 24 25 29 30 31error: detection failed (19 tries), read flash and send to support
Finished, time used: 17 sec
Still no luck, hope Infinity Support will release another update for this type ...
thanks
Old 07-25-2009, 18:13   #4 (permalink)
Member: 130995
Hello,
Thanks for reports !
We will try to add this model ASAP.
You have full flash backup, so you can try to make this:
1. make "format ffs"
2. restore imei
What is the results ?
Also, what code phone ask when you power-on phone with sim card ?
Old 07-26-2009, 06:58   #5 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
Originally Posted by InfinitySupport View Post
Hello,
2. restore imei
Hello,
The phone not ask for code, just want to unlock it coz phone SIM 1 is locked to EXCELCOMINDO .
thanks for reply
Old 07-26-2009, 11:51   #6 (permalink)
Member: 130995
Hello,
What is this provider MCC/MNC ?
Old 07-26-2009, 15:05   #7 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
Hello,
MCC : 510
MNC : 11
Brand : XL
thanks
Old 07-27-2009, 19:34   #8 (permalink)
Member: 130995
Hello,
Please, use this new test software: http://www.infinity-box.com/download...dule_v2.83.rar
Please, try to unlock phone by different unlock methods, let's see results.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 07-28-2009, 15:18   #9 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
Hello,
Same result ...
COM5 [VCP0] selected
module v2.83
Device: Nexian-NX-G700
Action: "sp-unlock"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
921600
Set baud Done
ffs address assigned: 00E00000
sim-lock status: unknown
reading: Nexian-NX-G700_TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E2 01B_FM_PR1_IN_V0_7__ffs...
file saved: D:\Program Files\InfinityBox\MModule\Nexian-NX-G700_TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E2 01B_FM_PR1_IN_V0_7__ffs_20090728-131325.B0E.bin
error: phone is not locked or unknown eeprom
detecting parameters to apply patch area 0/...
Write: area 0/1
error: flash write error: 00140000:00002000
error: can't write required area
error: area 0/ can not apply patch
Write ...
error: no any expected answer : wrong answer after chip id request
error: no any expected answer : wrong answer after chip cfi request
Write Fail
Finished, time used: 416 sec
module v2.83
Action: unlock
Model: Nexian-NX-G700
19200 autodetect
CPU: MT6223
status: FF
Date: 2000.00.00
Version: 1.0
80 byte(s) read
connection Ok
186 byte(s) read
reading data...
reading data #2...
reading data #4...
reading data #5...
WARNING ! Unknown lock structure !
Read flash and send to support: [email protected]
Finished, time used: 32 sec
unlock method : read codes
module v2.83
Action: read codes
19200 autodetect
CPU: MT6223
status: FF
Date: 2000.00.00
Version: 1.0
80 byte(s) read
connection Ok
186 byte(s) read
reading data #4...
reading data #5...
error: source data size is less than expected
Finished, time used: 10 sec
unlock method : standard fast
module v2.83
Action: "sp-unlock"
unlock method: standard fast
Unlock procedure can be faster if you skip ffs/eeprom area backup procedure.
Do you want to disable ffs/eeprom backup ?
ffs/eeprom backup disabled
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
921600
Set baud Done
lock area found
lock area found
Write: area 0/1
Write ...
error: can't detect chip at required chip base
Write Fail
Finished, time used: 293 sec
thanks
Old 08-04-2009, 07:02   #10 (permalink)
Member: 660421
Thanks Meter: 26
more than 7days & still waiting,..
when infinity support release solution for it.... ????
thx
Old 08-04-2009, 18:16   #11 (permalink)
Member: 130995
thx
Hello,
Yes, I am also surprised that this time Infinity-Box has such delay due to ordinary Infinity-Box need only 1 (one) day to prepare new solution.
I think that this kind of delay means that new update will be for models that is not so easy to unlock.
Btw, do you know the difference in "press big unlock button and unlock phone with Infinity-Box in several seconds" and "create new solution" ?
Old 08-04-2009, 20:33   #12 (permalink)
Member: 130995
"MModule" v2.83 released, please try to use it: 05 Aug 2009: MyWay, Konka, LG, GLP, Nexian, MyPhone...
Old 08-05-2009, 13:50   #13 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
Hello,
Try today :
Standard methode :
module v2.83
Action: "sp-unlock"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
921600
Set baud Done
file saved: D:\Program Files\InfinityBox\MModule\Nexian-NX-G700_TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E2 01B_FM_PR1_IN_V0_7__ffs_20090805-193932.B0E.bin
Write: area 0/1
area 0/ patch applied Ok
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
Finished, time used: 184 sec
OK, but phone still locked ...
Smart Fast methode :
module v2.83
Action: unlock
19200 autodetect
CPU: MT6223
status: FF
Date: 2000.00.00
Version: 1.0
80 byte(s) read
connection Ok
186 byte(s) read
reading data...
reading data #2...
reading data #4...
reading data #5...
Finished, time used: 11 sec
thanks
Old 08-22-2009, 09:51   #14 (permalink)
Edocomsel's Avatar
Member: 76239
Sonork: 100.1584414
Thanks Meter: 210
Hello,
Standard Methode :
COM18 [VCP2] selected
module v2.84
Action: "sp-unlock"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
detect device rom info...
detect device rom info finished
rom info structure: 2nd [standard] generation
rom info detection finished
rom info protocol ver: 05
detect device sec info...
detect device sec info finished
file saved: D:\Program Files\InfinityBox\MModule\Nexian-NX-G700_TINNO23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.E2 01B_FM_PR1_IN_V0_7__ffs_20090822-153915.B0E.bin
detecting parameters to apply patch area 0...
error: area 0 can not apply patch
Write ...
Write: eeprom
Write Done
Finalization ...
Finalization Done
Finished, time used: 148 sec
Still locked
Standard Fast methode :
COM18 [VCP4] selected
module v2.84
Action: "sp-unlock"
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
460800
Set baud Done
lock area found
lock area found
Write ...
Write: lock-area-1
Write: lock-area-4
Write Done
Finalization ...
Finalization Done
Finished, time used: 71 sec
Still locked
Using smart fast give " Range Check Error"
thanks
Old 08-22-2009, 20:06   #15 (permalink)
Member: 130995
Hello,
We hope to release new software with updated unlock method for this model ASAP.
Nexian nx-910 frimware mbah_gondrong Various CDMA/TDMA Cell Phones 2 06-02-2011 17:30
need nexian nx G911 flash file ahmad riza virs CPF-BOX Ⅱ 3 11-08-2009 03:38
need Nexian NX-G900 sim unlocker klise17 Phone Unlocking Codes & Maps 0 06-26-2009 09:17
How to Unlock Nexian NX-810 Whonk Khito Various CDMA/TDMA Cell Phones 1 06-23-2009 01:43
nexian NX G500 djiphone76 SpiderMan 0 01-19-2009 14:41
Page generated in 0.53113 seconds with 8 queries
