Old 01-02-2009, 12:15   #1 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
Sony-Ericsson-T303 Unlock Done
COM3 [VCP2] selected
module v1.
Device: Sony-Ericsson-T303
"advanced chip detection" active
Action: unlock
Checking data, wait...
Boot ...
Press Power button now !
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection ...
Check connection done
Set baud ...
Set baud done
Check hardware ...
flash: 89890400040089:89890400000000
flash: Intel ST [def 0080x040000] 32Mb
software version: 1209-8242
software version: R2CA005
Check hardware done
Read data ...
reading Sony-Ericsson-T303_eeprom_calibration-1...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20090102-161221.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 213 sec
Remove/Install battery now !
UMER
The Following 2 Users Say Thank You to maplegsm For This Useful Post:
Old 01-02-2009, 23:15   #2 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works and what is
possible problems (so we will be able to fix it) and successfully done work.
Old 01-03-2009, 08:43   #3 (permalink)
Member: 36262
Thanks Meter: 26
hi
COM13 [VCP2] selected
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
error: operation failed
Finished, time used: 46 sec
module v1. ???????? maplegsm
Old 01-03-2009, 10:22   #4 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 391
t303 unlock done
COM4 [VCP0] selected
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
software version: R2BC003
Check hardware done
Read data ...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20090103-005937.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 209 sec
br
yasermalik
Old 01-03-2009, 13:26   #5 (permalink)
Zaihtam's Avatar
Member: 98572
Thanks Meter: 36
COM12 [VCP2] selected
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
Finished, time used: 48 sec
Not working...
GOod Luck...
Old 01-03-2009, 13:57   #6 (permalink)
irish_4's Avatar
Member: 79870
Thanks Meter: 52
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
Not working...
GOod Luck...
Its new security...i think you phone is 08W48 just check the label at the back...and thres is no solution yet. At the moment we can only unlock 08W47
Old 01-03-2009, 14:08   #7 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
try with COM1 baudrate should be select 115200 please post the results
UMER
Old 01-05-2009, 09:31   #8 (permalink)
Member: 36262
Thanks Meter: 26
COM1 [Serial0] selected
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
rom version: 0502
booting...
finalizing...
Boot fail
Finished, time used: 56 sec
Old 01-05-2009, 15:04   #9 (permalink)
vjohn456's Avatar
Member: 585634
Thanks Meter: 45
COM5 [VCP0] selected
Action: unlock
Boot...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection...
Set baud...
812500
Set baud done
Check hardware...
Check hardware done
Read data...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20090105-194409.80E.bin
Read data done
Check data...
Check data done
Writing...
Write: simlock
Writing done
Finished, time used: 106 sec
The Following User Says Thank You to vjohn456 For This Useful Post:
Old 01-05-2009, 20:16   #10 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 213
@Jurgis
It may be phone with new hardware type
Old 01-18-2009, 09:44   #11 (permalink)
Member: 468952
Thanks Meter: 16
COM15 [VCP1] selected
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
Remove/Install battery now ! Not working
Old 01-18-2009, 14:58   #12 (permalink)
Member: 130995
Thanks Meter: 35,227
http://forum.gsmhosting.com/vbb/show...41&postcount=6
Old 01-18-2009, 15:05   #13 (permalink)
Member: 152547
Sonork: 100.1586021
Thanks Meter: 143
same here
COM15 selected
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Set baud ...
115200
Set baud done
Check hardware ...
Check hardware done
Read data ...
file saved: C:\Program Files\InfinityBox\HModule\Sony-Ericsson-T303_eeprom_calibration-1_20090117-113300.80E.bin
Read data done
Check data ...
Check data done
Write ...
Write: simlock
Write done
Finished, time used: 203 sec
Old 01-18-2009, 15:12   #14 (permalink)
Member: 152547
Sonork: 100.1586021
Thanks Meter: 143
power off the phone
connect cable
then immediately insert battery
good luck
Old 02-11-2009, 08:20   #15 (permalink)
fazi52's Avatar
Member: 904326
Thanks Meter: 62
rong answer
Action: unlock
Boot...
rom version: 0502
Connecting...
booting...
finalizing...
Boot done
Check connection...
Set baud...
812500
Set baud done
Check hardware...
Check hardware done
Read data...
Read data done
Check data...
Check data done
Writing...
Write: simlock
Writing done
COM10 [VCP0] selected
module v1.30
Action: unlock
Boot ...
rom version: 0502
Connecting...
booting...
finalizing...
Boot fail
Finished, time used: 51 sec
The Following User Says Thank You to fazi52 For This Useful Post:
sony ericsson t303 unlock done by infinity box zinoubinabil Infinity-Box 18 11-23-2011 13:08
Sony Ericsson T303 Unlock Done 100% ms_ahmed SETool2 2 07-20-2011 21:12
Sony Ericsson T303 Unlock Done 101% ms_ahmed SETool2 19 03-04-2010 14:51
Sony Ericsson T303 Unlock Done ! .:Towhid:. SETool2 2 03-16-2009 15:06
Sony-Ericsson-T303 Unlock Done .:Towhid:. Infinity-Box 2 11-11-2008 10:56
Page generated in 0.24230 seconds with 9 queries
