can't unlock sagem my220x sagem my220x vergine mobile can't unlock hire is log COM4 [VCP0] selected module v1.62 Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 5 Press and HOLD Power button now ! loading... error: can't run preloader: try to use another loader type middle part... error: can't run middle loader: try to use another loader type Finished, time used: 8 sec Remove/Install battery now ! i also try with different loader type but no result |
can't read eprom and can't make reset satting too :confused::confused::confused:COM4 [VCP0] selected module v1.62 Device: Sagem-my220x Checking data, wait... Action: read eeprom Boot ... loader: standard type: 5 Press and HOLD Power button now ! loading... error: can't run preloader: try to use another loader type middle part... error: can't run middle loader: try to use another loader type Finished, time used: 9 sec Remove/Install battery now ! |
unlock in another method and post result Guljee |
there is no other mathod only mathod1 and restore opsation |
looks like cable problem,try with another cable and also change com port settings. |
i unlocked many phone with this cable |
bro reinstal pana1 module reset phone than unlock |
install pana01 v1.61 and try to unlock and post result Guljee |
[QUOTE=guljee786;4145681]install pana01 v1.61 and try to unlock and post result thanx i try pana01 v1.60 and unlock don hire is log COM4 [VCP0] selected module v1.60 Device: Sagem-my220x Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... middle part... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:011A Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-static_20090211-131225.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-security_20090211-131226.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_eeprom-complete_20090211-131231.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Sagem-my220x_lock-area_20090211-131256.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 94 sec Remove/Install battery now ! |
Hello, Thanks for information ! We will double check wht may be wrong with v1.62 |
Gul jee good guide good unlocker mushtaq |
