07-02-2007, 06:02 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Jan 2005 Location: U S A / GOA /CHINA Age: 44
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | @infinitiy cm_tool i have on hand n95 new release and want to know that is it supported by infinity or not cable direction ============================================= connector_1x8_mini.gif _________________ / 1 2 3 4 5 6 7 8 \ ------------------- ============================================= also needed pinout proper to check |
07-02-2007, 07:37 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, If phone cpu name like MT62xx this phone is supported. It's no need to ask "supported or not". Just read carefully software functions description and you will get all information very easy. cable: check FAQ thread to get info how to find pinout. Dont forget to post here pinout after you will find it. |
07-02-2007, 08:21 | #3 (permalink) |
Member: 106367 Status: Offline Sonork: 100.1577436 Thanks Meter: 2,452 | @infinity ya it is =MT6226BA GONE THROUGH FAQ [PLS HELP TO FIND PINOUT ] CHARGING PIN IS ============================================= connector_1x8_mini.gif _________________ / 1 2 3 4 5 6 7 8 \ ------------------- ============================================= 3=5.5 V[+V] 4=5.5 V[+V] 8=GND Last edited by chiragp; 07-02-2007 at 08:49. |
07-03-2007, 13:56 | #6 (permalink) |
Temporary banned !! Join Date: May 2005 Age: 39
Member: 148045 Status: Offline Thanks Meter: 17 | hi if you tesy this pinout and not work so you have unknown cable so try this way ,that is from infinty team How to find pinout for unknown model: In most cases you need to know Gnd, Rx, Tx pins for flash/unlock operations. What do do if you don't have cable or you have new phone model: 1. find Gnd pin (it's required step, you can't continue until you will know Gnd pin location) 2. find Charge pins (it's optional step, just to save your time during future research) 3. find +Battery pins (it's optional step, just to save your time during future research) 4. connect cable Gnd to phone Gnd 5. try to connect cable Rx/Tx wires to all phone contacts one by one (except Gnd, Charge, +Battery pins) and try to read flash from phone 6. if flash read procedure can start this means that pinout found Ok and you can make other operations Note about "Chinese models": a lot of different phones with the same name exist on market (as well as many different name phones with the same pinouts), so, if you see in our "cable selector" wrong pinout for "Chinese models"it's good idea to find correct pinout acording to above instruction and send found pinout information with full text from phone back label to [email protected] |
