Old 03-22-2007, 14:01   #1 (permalink)
Member: 2899
Thanks Meter: 6
cant unlock vk200!
hi
im trying to unlock vk200 with vkwhat downloader,but when i click start,it says usb connection failed,im using the usb lead which came with the fone,unless im using the wrong lead,help if u can,thnx
br
farry
Old 03-22-2007, 19:38   #2 (permalink)
Member: 104066
Thanks Meter: 62
if u want to unlock this phone use flash cable :
connector pin count: check pinout_VK2000.gif
Connector mini 5x2 (like Nec-N343i)
1 2 3 4 5
6 7 8 9 10
=== user code, Imei ===
use original usb cable from phone package (pinout available at end of this page)
2: USB +power
3: USB D- (white)
4: USB D+ (green)
6: Gnd
=== Flash, sp-unlock ===
2: USB +power
3: USB D- (white)
4: USB D+ (green)
5: Gnd
6: Gnd
Old 03-22-2007, 19:41   #3 (permalink)
Member: 104066
Thanks Meter: 62
power off phone insert cable to phone
press power button
insert cable to phone and install drivers
now u can unlock u phone in 2s
Old 03-22-2007, 20:32   #4 (permalink)
Irfangk786's Avatar
Member: 146630
Thanks Meter: 21
Originally Posted by farry View Post
hi
br
farry
infinityteam had explain much about Vk200 always search befor post
http://forum.gsmhosting.com/vbb/show...ighlight=vk200
Old 03-23-2007, 01:26   #5 (permalink)
Member: 2899
Thanks Meter: 6
thnx for the tip m8.
br
Old 04-11-2007, 09:57   #6 (permalink)
Member: 477355
Thanks Meter: 20
i have a c168 in which the problem is , everytime it says battery low but the battery is ok as it is working on another mobile ,
after charging the set for many hours it does not shows full charging and when we take the charger out it again says battery low ..
Old 04-11-2007, 18:12   #7 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Please, check phone hardware.
Old 05-20-2007, 19:17   #8 (permalink)
Member: 511814
Hello,
I can't unlock this vk200 although I have already unlocked some pieces with flash cable.
______________________________
Loading data, wait...
S/N: xxxx:xxxx
Current model: VK2000
Ready
Action: Reset settings
Model: VK200
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected Ok, wait...
Region: France TELE2
Hardware version: VK200_1A00
Software version: VK200_SZ0.93R
battery parameter: 488
Imei: 35950200xxxxxxx
Finished
Remove/Install battery now !
Time used: 11 sec
___________________________________
I can't enter another sim card, it's always Locked to network
I already reseted the phone
What's the solution please ?
Thx for helps
Old 05-21-2007, 22:24   #9 (permalink)
Member: 511814
No one was confronted with this pb or have an idea on it ?
Cant unlock Sony-Ericsson-J132 rajhcl0 Infinity-Box 3 03-29-2010 18:28
how unlock VK200 chavrotti Various 14 08-30-2008 14:39
>> How to unlock VK200 << GsmTower Various 16 02-15-2007 20:53
unlock VK200 is not possible ? hitibiti Infinity-Box 5 01-17-2007 17:42
How to unlock VK200 ? pyroz Infinity-Box 4 12-17-2006 16:19
Page generated in 0.23595 seconds with 9 queries
