Old 12-09-2009, 18:49   #1 (permalink)
Member: 1026122
Sonork: 100.1640842
Thanks Meter: 127
Can't unlock zte-a36+???????
Dear Infinity team
I try to unlock zte-a36+ but when I select the a36+ in the shell..it is going to chinesmiracle ...and there nothing is happening..also phone is not detecting but In pinfinder is detected
cable type: 1x8 (L8A)
platform: CPU independent (autodetect) algorithm
searching adapter at COM6...
adapter found, version: 2000
pins: 8, plain
power cycles: 1
activation cycles: 5
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Phone should be Powered-On !
Power-On phone now and press "Ok"
Be sure that phone is not in sleep mode during pinout detection !
Press any phone key from time to time to wake-up phone.
detecting pins...
detected baudrate: 115200
result: Rx:1 Tx:2
time required: 0 sec
But I selected A36 and run the exe....there every thing is ok and unlocked but the phone is not unlocked...
==== log: [12/9/2009 11:24:53 PM] ====
COM6 [VCP4] selected
module v1.71
Device: ZTE-A36
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
sw version: ICA-P108A8FM Z B01-EnEs-PE02 g3dBV2.0 Jan 17 2008 10 39 35 10 39
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-static_20091209-232511.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-security_20091209-232512.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-complete_20091209-232519.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_lock-area_20091209-232531.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 51 sec
Remove/Install battery now !
So..please help me to unlock this phone
Old 12-09-2009, 21:12   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
What text you see at phone LCD when you power-on phone with wrong sim card ?
Old 01-25-2010, 19:04   #3 (permalink)
Member: 214178
Hello
A36+
SIM LOCKED
Old 03-10-2010, 09:40   #4 (permalink)
Member: 945056
Sonork: 100.1617497
Thanks Meter: 4
any crack to unlok zte a 36
Old 03-10-2010, 14:49   #5 (permalink)
Member: 1043909
Thanks Meter: 51,303
Did you tried to use Infinity-Box ?
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 03-27-2010, 10:40   #6 (permalink)
skytelecom's Avatar
Member: 1074229
Sonork: 100.1605299
Thanks Meter: 62
unlocked a36+
when i insert a sim its says simlock
COM1 [Serial0] selected
module v1.72
Device: ZTE-A36
Action: unlock
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 00EC:22A0
Connecting Done
Check hardware ...
sw version: LAT-P108A6FMB01-En-AF02 g3dBV2.0 E-AF-ETISALAT-P108A6FMV1.0.0B02
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-static_20100325-170408.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-security_20100325-170409.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-complete_20100325-170415.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_lock-area_20100325-170427.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Old 08-06-2010, 15:40   #7 (permalink)
Member: 1362100
Sonork: 100.1656342:dr.mobile
Thumbs up successful unlock ZTE 36+
infinity-pana01
COM6 [VCP0] selected
module v1.78
Device: ZTE-A36
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-static_20100806-190711.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-security_20100806-190712.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-complete_20100806-190718.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_lock-area_20100806-190731.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
WORK WITH ANY SIMCARD
Old 01-20-2011, 10:30   #8 (permalink)
NAVEED74's Avatar
Member: 188574
Sonork: 100.1590742
Thanks Meter: 750
successfully unlocked ZTE A36+ with Infinty
here is the log.
COM38 [VCP0] selected
module v1.78
Device: ZTE-A36
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
slowest
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-static_20110120-145300.B1E.bin
loading data...
data loaded
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-security_20110120-145301.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_eeprom-complete_20110120-145308.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A36_lock-area_20110120-145320.B1E.bin
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 49 sec
Naveed
Old 04-08-2011, 01:26   #9 (permalink)
Member: 51063
Thanks Meter: 4
COM12 [VCP0] selected
module v1.71
Device: ZTE-A36
Action: unlock
unlock method-1
Boot ...
e-gold: 820013
loading...
error: can't run preloader: 01
Boot Failed
Finished, time used: 24 sec
Old 04-08-2011, 01:28   #10 (permalink)
Member: 51063
Thanks Meter: 4
any help how can fix this issues?
Old 05-18-2011, 11:04   #11 (permalink)
Member: 710668
Thanks Meter: 72
module v1.71
Device: ZTE-A36
Action: unlock
unlock method-1
Boot ...
e-gold: 820013
loading...
Boot Failed
same here......
any advice from the supporter?..
Old 05-18-2011, 16:01   #12 (permalink)
Maik_TechService's Avatar
Member: 846968
Sonork: 100.1613167
Thanks Meter: 139
Lightbulb Inifinity not support
hello bro this e-gold not support by infinity box
Old 05-18-2011, 16:02   #13 (permalink)
Member: 846968
Sonork: 100.1613167
Thanks Meter: 139
e-gold: 820013
loading...
Boot Failed
not support we wait update ????????
Old 05-19-2011, 08:03   #14 (permalink)
Member: 710668
Thanks Meter: 72
Originally Posted by NAVEED74 View Post
here is the log.
module v1.78
Device: ZTE-A36
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820000
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
slowest
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Naveed
HOW ABOUT THIS ONE, ISNT THIS "egold"?....
can't unlock zte a37 devil6684 Infinity-Box 6 09-28-2017 00:55
Is it possible to unlock ZTE-A36+ sky_finder Infinity-Box 17 05-23-2014 03:11
I can`t unlock ZTE A36+ [ANSWERED] toņocom PolarBox 3 1 01-25-2010 19:18
unlock zte A36 DRA puumba FuriousGold 2 08-02-2009 18:15
problem with unlock ZTE A36 volamihamina Infinity-Box 1 04-29-2008 08:35
Page generated in 0.48021 seconds with 8 queries
