Old 04-28-2009, 22:32   #1 (permalink)
Member: 549150
Thanks Meter: 3
can't unlock zte a37
i follow the pinout that is on shell and i have cable zte-2010 but infinity box can't detect my phone?
Old 04-30-2009, 20:03   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
Double check your cable, probably you need to swap Rx <-> Tx.
If problem still exist post here operation log so we will be able to understand what is wrong.
Old 05-01-2009, 02:55   #3 (permalink)
Member: 549150
Thanks Meter: 3
yes i did it i managed to unlock this phone there is only one little thing pinout it's wronggg the right pinout for zte a37 is
key board top
1............18
8-ground
13-box tx
14 box rx
the only thing now is that i have to change the ftdi chip due to wrong conection
here is full log
COM1 [Serial0] selected
module v1.32
Device: ZTE-A37
Checking data, wait...
Action: unlock
Boot ...
Press and HOLD Power button !
Connecting, wait...
Release Power button !
flash: EC257E25062501:70E59F00000000
flash: AMD/Fujitsu std [D 0008x002000 007Ex010000 0008x002000] 8Mb
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 356624017560637
file saved: E:\Program Files\InfinityBox\AModule\eeprom_356624017560637_Z TE-A37_20090430-184826.98E.bin
Check flash Done
Check space ...
file saved: E:\Program Files\InfinityBox\AModule\_eeprom-calibration_20090430-184837.98E.bin
file saved: E:\Program Files\InfinityBox\AModule\_eeprom-ffs_20090430-184919.98E.bin
reading lock-area-2...
file saved: E:\Program Files\InfinityBox\AModule\lock-area-2_ZTE-A37_20090430-184934.98E.bin
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 282 sec
Remove/Install battery now !
ill try to find the right pinout for coral 500
8 pin mini usb now
thanks infinity team
The Following User Says Thank You to devil6684 For This Useful Post:
Old 05-01-2009, 08:55   #4 (permalink)
Member: 130995
Hello,
Are you sure that GND for A37 is pin 8 but not pin 11 ?
Please, double check it.
Also it may be that pin 8 and pin 11 both connected to GND.
Please, check it if you still have phone on hands.
Old 05-01-2009, 23:46   #5 (permalink)
Member: 549150
Thanks Meter: 3
yes sir pin 8 works for me ill make another log but first i have a problem i have 5 different zte to unlock and the main in all of them got the bands deactivated so i tried to flash it with the files in support area but every time i try to flash the program flashes the phone but when it's almost finished the program restart connecting again
Old 09-21-2017, 15:47   #6 (permalink)
Member: 1652269
Sonork: 100.1638989
Thanks Meter: 54
zte a37 need rx tx point
Old 09-28-2017, 00:55   #7 (permalink)
Member: 130995
yes you are right, you need rx/tx/gnd cable
Can't unlock zte-a36+??????? sky_finder Infinity-Box 13 05-19-2011 08:03
Can't unlock ZTE-G X760! [Too old already supported] GSMBlade Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 22 04-23-2011 21:41
i can't unlock ZTE A61 by infinity box shetos17 Infinity-Box 7 05-27-2010 11:17
can't unlock ZTE MD2 sajib_ngage VygisToolbox 0 01-18-2010 10:23
i can't unlock ZTE A61 by infinity box shetos17 Infinity-Box 1 09-28-2009 18:24
Page generated in 0.36718 seconds with 8 queries
