02-16-2012, 12:24 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 665242 Status: Offline Thanks Meter: 16 | can't update dongle !! Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs. Dongle is up-to-date and has latest firmware. DO NOT try more ! MModule require latest dongle update, but i can't update. What to do next?? |
02-16-2012, 14:04 | #2 (permalink) |
Freak Poster Join Date: May 2005 Age: 57
Member: 148055 Status: Offline Thanks Meter: 2 | after activation 1year open dongleManager message ----------Process started: 15/02/2012 19:29:07---------- DongleManager version: 1.41 Locating server... Server address found#1 Connecting to server#1... Server connection successfully established S/N: 02xxxx8D, Firmware: 0118.02 Authenticating on server... Authentication stage error: Server reported error:[0006] Your account is suspended: read previous error messages carefully and contact to [email protected] See more information in C:\Documents and Settings\ORDINATEUR\Mes documents\Téléchargements\DongleManager\DongleMana ger.log file. please help me Last edited by InfinityHelp; 02-18-2012 at 10:41. |
02-16-2012, 14:05 | #3 (permalink) |
Member: 148055 Status: Offline Thanks Meter: 2 | ----------Process started: 16/02/2012 13:04:48---------- DongleManager version: 1.41 Locating server... Server address found#1 Connecting to server#1... Server connection successfully established S/N: 02xxxx8D, Firmware: 0118.02 Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs. Dongle is up-to-date and has latest firmware. DO NOT try more ! Last edited by InfinityHelp; 02-18-2012 at 10:39. |
02-16-2012, 17:47 | #4 (permalink) | |
Did you checked, when your support period expired ? It may be that you need to renew support. | |
02-16-2012, 17:48 | #5 (permalink) | |
Please, update your box firmware once again now. Waiting for your results. Last edited by YellowBoss; 02-16-2012 at 18:45. | |
02-18-2012, 01:17 | #6 (permalink) |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | I am having the same problem, what could be the solution? Code: DongleManager version: 1.41 Locating server... Server address found#1 Connecting to server#1... Server connection successfully established S/N: 9Fxxxx2F, Firmware: 0118.02 Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs. Dongle is up-to-date and has latest firmware. DO NOT try more ! Last edited by InfinityHelp; 02-18-2012 at 10:39. |
02-18-2012, 10:31 | #7 (permalink) |
Freak Poster Join Date: May 2007
Member: 511368 Status: Offline Thanks Meter: 23 | I can't update dongle after active 1 year support DongleManager version: 1.41 Locating server... Server address found#1 Connecting to server#1... Server connection successfully established S/N: 0xxxxxxx, Firmware: 0118.02 Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs. Dongle is up-to-date and has latest firmware. DO NOT try more ! Last edited by InfinityHelp; 02-18-2012 at 10:39. |
02-18-2012, 10:37 | #8 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
you have latest avilable version 1.18. no need to upgrade it more. Ver 1.20 is only for boxes with active (extended) support. | |
02-18-2012, 10:38 | #9 (permalink) | |
please make upgrade one more time | |
02-18-2012, 10:40 | #11 (permalink) | |
please make one more box upgrade | |
02-18-2012, 12:19 | #12 (permalink) |
Freak Poster Join Date: Nov 2003 Location: eibar Age: 56
Member: 43045 Status: Offline Thanks Meter: 7 | no upgrade box.... ---------Process started: 18/02/2012 11:48:30---------- DongleManager version: 1.41 Locating server... Server address found#1 Connecting to server#1... Server connection successfully established S/N: 08xxxxB5, Firmware: 0118.02 Authenticating on server... Authentication stage error: Server reported error:[0007] No more upgrade logs. Dongle is up-to-date and has latest firmware. DO NOT try more fonolibre spain Last edited by InfinityHelp; 02-18-2012 at 20:26. |
02-18-2012, 20:26 | #13 (permalink) | |
you have latest avilable version 1.18. no need to upgrade it more. Ver 1.20 is only for boxes with active (extended) support. read more here: Infinity-Box Technical Support • View topic - How to fix "You should extend your support period" | |
02-18-2012, 23:47 | #15 (permalink) | |
Yes. Here is you can see more details: http://forum.gsmhosting.com/vbb/f296...012-a-1391471/ | |
Nokia dongle problem... | omelette | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-05-2000 17:58 |
dongle.exe | Aldrin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 01-22-2000 04:40 |
I will finished Dongle for Nokia WinTesla | MyKy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-14-1999 22:47 |
