Old 01-29-2017, 08:51   #1 (permalink)
Member: 2298369
Thanks Meter: 440
Oppo a1601 pattern lock removing error
I TRY TO REMOVE PATTERN LOCK OF OPPO A1601 , IT SHOW-
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:27
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BB_CPU_NME : [MediaTek] Helio[P10]|MT6755_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x01000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : SIGNED with SPRELOADER
Processing DA stage
Sending and initialize DA ...
DAgent configured successfully
Connection agent : BROM
DRAM configured from IDB!
Link with DAgent established
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , BM41C
[eMMC] : FLASH_CID : 150100524331344D42070099C829A3B7
[eMMC] : FLASH_LEN : 0x0000000E8F800000
[eMMC] : FLASH_UCP : 59640 MiB [eMMC 128 GiB]
DEV RID : 0xECADEC52C740906F957FCD7844949F8D
INT RAM : 0x00000000
EXT RAM : 0x80000000 [2 GiB]
[NAND] : FLASH : NOT INSTALLED
[UFSM] : FLASH : NOT INSTALLED
[HSUSB] : MODE : FULL-SPEED
Boot Ok!
Clear USERDATA
Format/Reset Error!
Operation Failed
Elapsed: 00:00:43
PLZ ADD THIS IN NEXT update.
Old 01-29-2017, 09:33   #2 (permalink)
Member: 2298369
Thanks Meter: 440
thanks *** ***, pattern read successfully-
Card found : S/N : 94FBD840 , v0134
Start at : [1/29/2017 / 1:49:17 PM]
Operation : Read Pattern/DP Lock [ v1.58 ]
Wait for phone...
Phone found! [ 27 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6755
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Boot Ok!
USBDL : Init HSUSB Ok
Reading data ...
Get Locks ...
PatternLock Sequnce : 145269
Done!
Elapsed: 00:00:20
really cm2 is unique.
Old 05-02-2017, 10:14   #3 (permalink)
Member: 2331456
please sir share ur tested files for this tricks badly needed
TIA
Old 05-02-2017, 10:28   #4 (permalink)
AnonDz's Avatar
Member: 2232889
Thanks Meter: 91
can any of you guys help me with the proper drivers for this phone
Page generated in 0.14398 seconds with 8 queries
