Old 11-05-2015, 05:52   #1 (permalink)
Cheater -Don't Deal with him-
Member: 54228
Thanks Meter: 76
cant work smart av infinity box
here is log
Clear Ok!
Operation : Remove Viruses [SmartAV] [ v1.35 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 11010030303447453001948B911C4257
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0011 , OEM : 0100
[eMMC] : FLASH_INF : 0EG40
[eMMC] : FLASH_CID : 11010030303447453001948B911C4257
[eMMC] : FLASH_EXT : 00200000/00080000
[eMMC] : FLASH_LEN : 0x00000000EC000000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scanning FileSystem now , please wait
Scan Done, infected files found : 1
Removing infected files and scripts ...
SmartAV Report : Removed 1 infected files!
Making additional operations ...
Special Op #1 : Clear Recovery Data Ok!
Special Op #2 : PostFix Ok!
Done!
Done!
Elapsed: 00:01:20
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.35 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:19
Old 11-05-2015, 06:08   #2 (permalink)
malka4u's Avatar
Member: 1626780
Thanks Meter: 696
which mode / brand your mobile is?
Old 11-05-2015, 07:49   #3 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,655
Smart AV show NO viruses inside.
Check and clear SD card and internal FAT memory.
Old 11-05-2015, 07:55   #4 (permalink)
BISMILLAH MOBILES's Avatar
Member: 610502
Sonork: 100.1618428
Thanks Meter: 158
Respected Jaydi Thanks..But..for information..
SmartAV Init Ok!
Done!
Is all this indicate that there is no any Virus inside the phone?
Cause when normally try to use AV command this type of answer shows in Logs. Not in every Mobile but some in some cases.....
Old 11-05-2015, 13:18   #5 (permalink)
kabul's Avatar
Member: 433097
Sonork: 100.1661890
Thanks Meter: 8,244
Originally Posted by BISMILLAH MOBILES View Post
SmartAV Init Ok!
Done!
Q Mobile A300 same problem Infected files found : 1
 Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
eMMC_ID : 90014A4834473164048600A33D9411B9
[eMMC] : FLASH_VEN : 0090 , OEM : 014A
[eMMC] : FLASH_INF : d1G4
[eMMC] : FLASH_CID : 90014A4834473164048600A33D9411B9
[eMMC] : FLASH_EXT : 00200000/00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
SOC VERIFY : C1
Boot Ok!
 SmartAV Init Ok!
Scan Done, infected files found : 62
 SmartAV Report : Removed 62 infected files!
 Done!
 Done!
Elapsed: 00:01:02
 Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
 SmartAV Init Ok!
Scan Done, infected files found : 57
 SmartAV Report : Removed 57 infected files!
 Done!
 Done!
Elapsed: 00:00:45
 Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
 SmartAV Init Ok!
 Done!
 Done!
Elapsed: 00:00:52
 Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
 Done!
Elapsed: 00:00:20
 Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
 SmartAV Init Ok!
 Done!
 Done!
Elapsed: 00:00:54
Operation : Check / Read Info [ v1.35 ]
 Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
 [AP] : Initial info read Ok!
 Brand     : QMobile
ProdName  : A300
ProdModel : QMobile A300
Device    : QMobile A300
AndroidVer: 4.2.2
MTKxCPU   : MT6572
MTKxPRJ   : ALPS.JB3.MP.V1.P65
 Done!
Elapsed: 00:00:09
Scatter Load Ok , BaseBand : MT6572 , Project : s7810bp , Storage : EMMC
Files found : 12 , Set to Flash : 11
Ready to Flash!
 Operation : Flash [ v1.35 ]
 ======= Flash
 Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
 ScatCFG : BaseBand : MT6572 , Project : s7810bp , Storage : EMMC
Setting : AFF verify :  Enabled
 BL : Check HW compatibility
BL : Check eMMC compatibility
 BL : BatteryLevel : 3880 mV
BL : BatteryLevel Ok
 BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002300000-0x00000000E3E00000
Flash Pre-Erase Done, time used : 00:00:08
 SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_s7810bp.bin
Preloader Sent , Init passed
PartCount : 0013
Update PMT by user request
Repartition Done!
 Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : ANDROID
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : USRDATA
Image Flash Ok
Flash now : FAT
Image Flash Ok
Flash Write Done, time used : 00:03:41
 Processing : Verify
Verify Passed : MBR
Verify Passed : EBR1
Verify Passed : UBOOT
Verify Passed : BOOTIMG
Verify Passed : RECOVERY
Verify Passed : SEC_RO
Verify Passed : LOGO
Verify Passed : ANDROID
Verify Passed : CACHE
Verify Passed : USRDATA
Verify Passed : FAT
Data Verify Done, time used : 00:01:27
 Update Mirror PMT
Update Done!
 Update RomInfo done
 Done!
Elapsed: 00:05:29
 Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
 SmartAV Init Ok!
 Done!
 Done!
Elapsed: 00:00:40
 Wait for phone...
Phone found! [ 8 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
 SmartAV Init Ok!
 Done!
 Done!
Elapsed: 00:00:38
Old 11-05-2015, 13:49   #6 (permalink)
JayDi's Avatar
Member: 462970
What "same"? When you guys will learn, how make posts and explanations? Correct explanations? Not just a waste time and space posts.
Old 11-06-2015, 05:10   #7 (permalink)
maomatrix's Avatar
Member: 901711
Sonork: 100.1606138
Thanks Meter: 423
jejejejejeje.. OH my ***.....
Page generated in 0.31360 seconds with 7 queries
