Old 02-02-2015, 09:10   #1 (permalink)
Member: 2320752
Thanks Meter: 9
intex aqua i-5
I have one intex aqua i-5 dead.
I checked hardware it is fine.Can I reive it with software?
there is no flash file in download site.Can you please help me arrange it?
Here is idfentify log,
Operation : Check / Read Info [ v1.10 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6583
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0001
BB_CPU_NM : [MediaTek] MT6583|6589_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 204A0190594E4958EBA11648DF40B302
DA Stat : v3.2 on BBID : 0x86
DA Sent. Configure setting now ...
DA start Failed!
Check battery , cable , drivers and try try again
Boot Error!
Operation Failed
Elapsed: 00:00:02
Reconnect Power/Cable!
Thanks,
Old 02-02-2015, 09:30   #2 (permalink)
Member: 459784
Sonork: +91-9179403087
Thanks Meter: 1,542
you cant do anything if loder erased!
find factory firmware and try to flash by factory Tool!
Old 02-02-2015, 10:12   #3 (permalink)
Member: 2320752
Thanks Meter: 9
Any idea? Where I could find it?
It is not available on moulnisky site.
Old 02-02-2015, 10:44   #4 (permalink)
Member: 459784
Thanks Meter: 1,542
you can read file from other working set! and post here ur gmail id i try to find file for u !
Old 02-02-2015, 16:21   #5 (permalink)
Member: 2320752
Thanks Meter: 9
I found file here but not flasher.
How can I flash it with cm2mtk?
It has scatter file & scatter file option is not highlighting.
http://forum.gsmhosting.com/vbb/f945...09/index2.html
Old 02-02-2015, 16:27   #6 (permalink)
VIJAY2U2's Avatar
Member: 1039903
Thanks Meter: 2,040
USE SP_Flash_Tool_v5.1352.01
The Following User Says Thank You to VIJAY2U2 For This Useful Post:
Old 02-02-2015, 16:41   #7 (permalink)
Member: 2320752
Thanks Meter: 9
When I load scatter file it says uboot checksum failed.
Any body has working file for intex aqua i-5?
I think this file has problem. It shows same error in SP_Flash_Tool_v5.1352.01 & in
SP_Flash_Tool_v3.1244.0 also.
Old 02-02-2015, 16:44   #8 (permalink)
Super Moderator
MyGSM World's Avatar
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Dear Friend,
Use This Latest SP_Flash_Tool.
http://forum.gsmhosting.com/vbb/10820432-post37.html
Post Result Please.
Old 02-03-2015, 07:20   #9 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
@jataarya
Intex Aqua-i5 uses flashing tool named- SPMultiPortFlashDownloadProject
Here is the link for official flasher for Intex Aqua-i5- tool-12052013
Br.
Old 02-03-2015, 08:26   #10 (permalink)
Member: 2320752
Thanks Meter: 9
Thanks,
It selects file but at the time of flashing it gives DA error.
It says "S_FT_ENABLE_DRAM_FAIL(4032)Auto polling number:0
What should I do?
Old 02-03-2015, 08:37   #11 (permalink)
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Check and select correct comport and select sel All Auto Pl option.
And this is Infinity support section so better post in intex sub forum for more support.
Br.
Old 02-03-2015, 08:59   #12 (permalink)
Member: 2320752
Thanks Meter: 9
I did as you told to do but same "DA ERROR"
Next time I will post in right section sorry.
Can I get bin file?To download with infinity CM2MTK
Old 02-03-2015, 09:11   #13 (permalink)
Super Moderator
Member: 1078689
Sonork: 100.1626373
Thanks Meter: 2,826
Thanks,
What should I do?
Dear Friend
Check It, http://forum.gsmhosting.com/vbb/f782...issue-1828199/
The Following User Says Thank You to MyGSM World For This Useful Post:
Old 02-03-2015, 16:41   #14 (permalink)
Member: 2320752
Thanks Meter: 9
Just for sharing,
Mobile revived with "tool-12052013" flasher & "INTEX_AQUA_I-5_V14_INDIAN_SER" flash file.
It was software fault only.
Thanks every body for help.
Old 06-17-2015, 17:02   #15 (permalink)
Member: 1052584
it is very simple contact on [email protected]
Page generated in 0.21717 seconds with 8 queries
