card update problem === DongleManager [Infinity] v1.70 [19-06-2017 18:52:15] === Searching... Box/Dongle can't be found Card with specified AID is not found |
- Run CardID software - http://www.infinity-box.com/support/?r=7 - Select Card-Reader - Click to "Read" button DO NOT send screenshot/video but copy/paste text from software window ! |
CardID software (TEXT) Card-Reader: Gemalto e-gate Smart Card 0 ATR: 3B759400006202020201 Card Manager: SerialNumber: 00032944 ROM: Integrated Circuit Fabricator: 4090 Integrated Circuit Type: 0062 OS: Identifier: 0011 Release Date: 0202 Release Level: 0100 EEPROM: Fabrication Date: 0016 Serial Number: 00032944 Batch Identifier: 0000 Module Fabricator: 1942 Module Packaging Date: 0016 IC Card Manufacturer: 1943 IC Em******* Date: 0016 Pre Personalizer: 1944 Pre Personalization Date: 0016 Pre Personalization Equipment Identifier: 0000C107 Personalizer: FFFF Personalization Date: FFFF Personalization Equipment Identifier: FFFFFFFF m_iopCard.Serial: 0003294400001942 Extended info: Card returned error message . ISO7816 error 0x6A86 (Wrong parameter(s) P1-P2. Incorrect parameters P1-P2 ) |
I do not see any problem with your card. Make this: 1. close all software 2. run ONLY DongleManager 3. read card S/N text ? |
Serial number (text) === DongleManager [Infinity] v1.70 [6/20/2017 9:44:52] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 |
That is the full text form S/N READER |
try to update dongle now |
try to update dongle same error MTK Module 1.58, SPD 1.25, QLM 1.11. they are working fine but i can not update to the latest version, Version: 0135; Registered: 2013-07-02; Expired: 2017-07-31; Support: Active. pls help |
update dongle error === DongleManager [Infinity] v1.70 [6/23/2017 8:47:48] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0003294400001942 === Process started: 6/23/2017 8:47:48 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
Try to update it now ONLY ONE TIME ! Result ? |
