02-17-2017, 19:15 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: still here Age: 40
Member: 185054 Status: Offline Thanks Meter: 22 | cat s30 frp pb Code: Operation : Identify [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 012CFA53 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 433907A08A78B1BB286AF2B20A01FF57 ID_BLOCK_L : 73C1A7A694955CCEC3417F0B1255972D Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! Code: Operation : Reset Settings [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 012CFA53 ID_BLOCK_I : 009600E1 ID_BLOCK_L : 433907A08A78B1BB286AF2B20A01FF57 ID_BLOCK_L : 73C1A7A694955CCEC3417F0B1255972D Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! |
The Following User Says Thank You to limsao For This Useful Post: |
02-17-2017, 19:49 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Follow as log says,, send mail to team Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Sent from my S_plus using Tapatalk |
03-06-2019, 14:42 | #4 (permalink) | |
Freak Poster Join Date: Jul 2016 Location: phillipines
Member: 2596094 Status: Offline Thanks Meter: 83 | Quote:
Use the latest version of cm2qlm 1.16 post log | |
03-06-2019, 15:00 | #5 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Slovakia BA Age: 51
Member: 25110 Status: Offline Thanks Meter: 79 | Card found : xxxxxxxx , v0137 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 210 [MSM8x09] ID_BLOCK_S : 0498B57B ID_BLOCK_L : 1B515FF8E220D9C300429ACA6259D73F ID_BLOCK_L : E75D0B32080130BA5FF5E37F7EF923B1 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
