10-12-2011, 19:30 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: TelServisHalo,Loznica, Serbia Age: 53
Member: 21365 Status: Offline Thanks Meter: 92 | CCK E71 with 6253 CPU module v3.31 Device: Autodetect 6253 NOR Checking data, wait... Action: write flash write: Firmware LIWEI53_09A_SLIM_PCB01_GPRS_MT6253_S00.BRAZIL_53SF _P3_0_V1_5_TV1120.BIN_FLNK5N6433ATM_AD11__fullflas h_20110831-144436.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs No licensed to produce fix... warning: firmware do not have this kind of fault nor area detection... interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6253:8A04:8A00 status: FF bbchip bl ver: FE NOR flash id[00C8]: 00EC:225400000000 [SAMSUNG] K5N6433ATM chip size: 8Mb otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 NAND flash chip: not installed internal RAM size: 00020000 external RAM: absent done Set baudrate (115200)... done interesting cpu type found: 6253:8A04:8A00 ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 00000000/00000000 detect sec ro... detect custom parameters... detect project-id... project-id: BRAZIL_53SF_P3.0_V1.5_TV1120 detect NOR info... number of areas/bytes to read: 1:00050000 reading (HW_STORAGE_NOR)... TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: LIWEI53_09A_SLIM_PCB01_GPRS_MT6253_S00.BRAZIL_53SF _P3_0_V1_5_TV1120.BIN_FLNK5N6433ATM_AD11 project-id: BRAZIL_53SF_P3.0_V1.5_TV1120, 00000000 code offset: 00000000 ffs offset/size [02]: 00700000/00100000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.31, database date: 19.08.2011): LIWEI53_09A_SLIM_PCB01_GPRS_MT6253_S00.BRAZIL_53SF _P3_0_V1_5_TV1120.BIN_FLNK5N6433ATM_AD11 This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare – Secure Data Logistics or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== startup code area #1 check... done number of cores: 1 loading files... number of areas: 1 done write... write core... error: can not write flash (6): 0FA8:S_FT_DOWNLOAD_FAIL error: last error: 0FA8:S_FT_DOWNLOAD_FAIL Disconnect... done Finished, time used: 2 min 49 sec Remove/Install battery now ! History: Phone are new and come to me to try translation...reeded full flash before anything, make translation, and after trying to write translated flash stops on 6% phone become dead....After that not reeded full flash can't write back to phone...every time error occurs sometime on 6% sometime on 10% or even 64%... QST: 1.these in start mean what? otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 2. these at write process mean what? error: can not write flash (6): 0FA8:S_FT_DOWNLOAD_FAIL error: last error: 0FA8:S_FT_DOWNLOAD_FAIL PS..it's not meter if I try to write flash with MModule or ChinaMiracle...a same error occur!!! |
10-13-2011, 18:34 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please tell us this phone history. where did you get flash file? what was the reason to flash this phone. which box/cable you are using as interface? |
10-13-2011, 19:05 | #3 (permalink) | |
Member: 21365 Status: Offline Thanks Meter: 92 | Quote:
"...History: Phone are new and come to me to try translation...reeded full flash before anything, make translation, and after trying to write translated flash stops on 6% phone become dead....After that not reeded full flash can't write back to phone...every time error occurs sometime on 6% sometime on 10% or even 64%..." 1. these is reeded full flash file from phone with MMmodule BEFORE any action! 2. I need to translate phone 3. Infinity Box with PinFinder , InfinityBox direct to phone PCB RX, TX, GND, VBat, Z3X Box, Vygis box, RockerBox...every Box on market with FTDI, with My old MAX RS232 interface on COM1, on every speed from SW, AutoBoot speed on-off, Boot on higest Baud rate On-Off...named what-I'm , possible, already tried!!!! So, be so kind and explain to me these from SW: QST: 1.these in start mean what? otp status/size: S_DA_NOR_OTP_NOT_SUPPORT/00000000 2. these at write process mean what? error: can not write flash (6): 0FA8:S_FT_DOWNLOAD_FAIL error: last error: 0FA8:S_FT_DOWNLOAD_FAIL Thank's Last edited by hallo; 10-13-2011 at 19:15. | |
10-14-2011, 20:35 | #6 (permalink) | |
Hosting your Files - AZIL 53SF P3 0 V1 5 TV1120 BIN FLNK5N6433ATM AD11 fullflash 20110831 144436 B0M bin B0M bin here You go, ORIGINAL flash file http://www.digzip.com/files/07ZSVBDA...144436.B0M.bin Last edited by hallo; 10-14-2011 at 20:40. | |
10-18-2011, 16:58 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this is just suggestion for making clear who's fault is this. our software or your phone. I would advise to use flashtool |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
