cdma tool error i have a cdma tool when i start tool software its show this msg............ SEND + RECEIVE ERROR. ISO7816 ERROR 0 X 6985 ( COMMAND NOT ALLOWED. CONDITIONS OF USE NOT SATISFIED. ):confused: |
i am useing cdma02 1.49 ....same problem need help infinity team |
no it is not working |
#20: How to fix problem with new smart-card type: IS07816 error 0x6E00 [class not supported] If you can not access support area: - use latest "Shell [Support manager]" If you can not run software: 1. download latest Smart-Card configuration file FSCard.ini 2. copy new Smart-Card configuration file FSCard.ini file in folder with software module Wbr <<<Megatron>>> |
problem solved thanks to infinity team .....thanks a lot |
What is your "same" problem exactly ? |
What was happened that dongle stop to work ? |
yes my cdma dongle was stop to work |
SEND + RECEIVE ERROR. ISO7816 ERROR 0 X 6E00 plz help] |
#20: How to fix problem with new smart-card type: IS07816 error 0x6E00 [class not supported] If you can not access support area: - use latest "Shell [Support manager]" If you can not run software: 1. download latest Smart-Card configuration file FSCard.ini 2. copy new Smart-Card configuration file FSCard.ini file in folder with software module. Wr. |
SEND + RECEIVE ERROR. ISO7816 ERROR 0 X 6E00 plz help |
Here Is Solution. http://forum.gsmhosting.com/vbb/7157887-post5.html Then Save It To C:\InfinityBox\cdma02 |
grate work infinity team Br. Lokesh |
