04-24-2008, 10:00 | #1 (permalink) |
Freak Poster Join Date: Apr 2007
Member: 496386 Status: Offline Thanks Meter: 6 | ceat p8300 after flash set not ok here is log COM1 selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection active Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom/ffs Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... chip: 0031:5028:C6E9 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb detecting chip #01 in region #00... flash: 01227E22202200:29EA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset assigned: 00E00000 flash: 01227E22202200:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... Can't detect eeprom/ffs area Do you want to use standard ffs address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard ffs address selected by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [eeprom]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_200 80424-123344.B0E.bin flash: 01227E22202200:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 Ok security area backup saved: id.A660DDEE.[M108_PCB01_GPRS_MT6226_S01.S518_HW_05C_S518BT.B_ZY ZX_G_V1.1.4.E.G_BUILD_NO.BIN_8847338D].rpl identification#1 detection finished device-id: A660DDEE identification#1 protocol ver: 04 ver. sw1: M108_PCB01_GPRS_MT6226_S01.S518_HW_05C_S518BT.B_ZY ZX_G_V1.1.4.E.G_BUILD_NO.BIN ver. sw2: S518BT.B_ZYZX_G_V1.1.4.E.G ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished security area#1 calculation file saved: backup_system_log_A660DDEE_M108_PCB01_GPRS_MT6226_ S01.S518_HW_05C_S518BT.B_ZYZX_G_V1.1.4.E.G_BUILD_N O.BIN_8847338D_20080424-123357.B0X.bin Area: Firmware flash: 01227E22202200:29EA0000000000 Write: Firmware Write Done file saved: backup_system_log_A660DDEE_M108_PCB01_GPRS_MT6226_ S01.S518_HW_05C_S518BT.B_ZYZX_G_V1.1.4.E.G_BUILD_N O.BIN_8847338D_20080424-123406.B0X.bin Finished, time used: 251 sec Remove/Install battery now ! but set is not ok plz helpppppppppppppppppppppppppp |
04-24-2008, 20:04 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! which flash you used for flashing? flashfiles/ChineseMiracle/_MT6205-MT6227/CM_Cect-P8100+_M108_PCB01_GPRS_MT6226_S01.S518_HW_05C_S518 BT.B_ZYZX_G_V1.1.4.E.G_BUILD_NO_16m_En_Cn_Hi_Cn_Ar .B0M.bin |
i flashed lg b2060 ....after flash set dead..help. | Rin2 | Infinity-Box | 2 | 03-21-2010 06:01 |
c160 flash okk different flash file but phone set not ok................ | vertex777 | UST Pro II | 2 | 11-30-2008 09:22 |
LG 8330 after flash set not open | khokonhajigonj | Cruiser Suite | 5 | 06-09-2008 22:28 |
d500 after flashing set still death | solution4mobile | UST Pro II | 0 | 02-25-2007 10:09 |
