11-08-2008, 00:15 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! are you sure about number of pins? also, is this phone is based on MT62xx MCU? tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
11-20-2008, 15:27 | #3 (permalink) |
Insane Poster Join Date: Jun 2006 Location: cold mountain
Member: 295823 Status: Offline Thanks Meter: 7 | Cect a200 21pins yes, i'm sure infinity team.i opened the unit and i was surprise of the 21 pins...problem is that the phone cannot be open to normal mode because the user forgot her security code,.i just need to unblock the code.. |
12-06-2008, 12:53 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! here only voltage measuring mthod will help: 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx when you find pinout make phone complete format, it will reset user code to default value |
need pinout sigmatel fxd 3600 | bassemzini | Infinity-Box | 0 | 03-29-2010 19:22 |
Need pinouts for Nktel-A200 | ZubairArain | Infinity-Box | 1 | 01-24-2010 08:52 |
CECT A200 PINOUT Please Help | jap_line | Infinity-Box | 2 | 08-09-2008 16:23 |
i needded pinout cect s500 pinout | anildeepak | Infinity-Box | 5 | 05-04-2008 09:38 |
help a want chemat of pines for cect a200 | algerienbox | Infinity-Box | 4 | 12-13-2007 21:01 |
