Old 06-11-2007, 08:28   #1 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 41
Chinese Miracle cable Pinout problems
Pls infinity team, lets get one thing straight, These are my questions:
1. Can we Modify just any universal box cable to use with chinese miracle?
2. Do we have to cut off the rj45 connector and solder directly to the main of the phone?
3. Or do we need to modify the usb cable that comes with the phones?
Most of us in this forum bought infinity just becos of these chinese models and now we're stuck cos we can't do a thing about it. Pls lets know where to start from and start helping ourselves.
Old 06-11-2007, 09:50   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
1. you can use any universal box cable or just use com port cable based on MAX232 IC.
2. if you dont have connector for phone- you have to solder wires directly to PCB or connector pins from PCB side.
3. You can take USB cable connector for building com port cable, but first you must make sure that needed pins are in connector
Old 06-11-2007, 11:28   #3 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 41
Will give it a try and post results. Thanks for your speedy response.
Old 06-11-2007, 17:54   #4 (permalink)
nishaon's Avatar
Member: 225229
Thanks Meter: 90
Infinity team is very aggresive in supporting their customers not like few other product supporters(cheaters).
Old 06-11-2007, 18:02   #5 (permalink)
david laborator's Avatar
Member: 228601
Thanks Meter: 56
......heh heh!!!.......
Old 06-11-2007, 18:21   #6 (permalink)
.::iRizwan::.'s Avatar
Member: 79937
Sonork: 100.84313
Thanks Meter: 4,715
Lightbulb
Not agressive but very Progressive
Old 06-11-2007, 18:25   #7 (permalink)
nishaon's Avatar
Member: 225229
Thanks Meter: 90
They are very quick, and response time is honourable.
Old 07-10-2007, 20:47   #8 (permalink)
Member: 52430
Thanks Meter: 3
hello!
hello,
pls i want to clear this cable building thing.
i got KONKA c966 phones. i checked for the pin out through cable selector software.
It says: KEYBORD TOP
1.............18
7hone Rx
9: phone Tx
18: GND
so i took an 18 pin usb cable (multibox RJ-45cable for 1180c) and opened the socket end. i desoldered the wires and then connected pins 7, 9, 18 as above description. It keeps writing connection fail.
what is wrong? i use the Rx/TX port of the box(left port). is it the right one or the right one marked RTS/CTS. is the switch supposed to be on fbus or mbus? or are we to use the back comport?. All these are to be clear to all infinity box users pls.
if we can't make cables, the box remains useless to us. what is the RJ-45 pinout description for Tx,RX,GND and cable colors.
These questions can remove some of our frustrations with box as infinity is carving a niche for itself on various mobile brands that their software are not common.
kudos to infinity team
Old 07-10-2007, 22:11   #9 (permalink)
Member: 148515
hello!
F-bus position.
you used left port- this is right.
now regarding pinout:
most common problem is tx, rx wires. try to change them with places.
should work. post result here
Old 09-02-2007, 00:20   #10 (permalink)
Member: 197538
Thanks Meter: 97
Infinity Team First I Would Like To Thank You For Your Quick Support ,,,
My Question Is I Orderd Infinity Chinese Cables And Somehow I Got Multibox Cables ... There Fore The Rx Tx Pins On Rj45 Are Different ,.,,
Can U Please Give Us Multi Box And Infinity Box Rj45 Pinout And Tell Us The Changes Because I Need To Change All Cables To Work With Infinity ...
Need Pinout Of Multibox And Infinity Box So I Can Correctly Change It ..please ...
Thanks A Lot
Mike
Old 09-04-2007, 12:49   #11 (permalink)
Member: 130995
Thanks Meter: 35,227
Thanks A Lot
Mike
Hello,
Infinity-Box pinout is here: http:///vbb/showpo...67&postcount=3
Old 09-04-2007, 15:01   #12 (permalink)
owoeye's Avatar
Member: 218859
Thanks Meter: 2
we need all your sopported chinese phone pinouts too.its very i m p o r t a n t
Old 09-04-2007, 15:51   #13 (permalink)
Member: 130995
Yes, I totally agree with you. 100% agree, even 1000% agree...
And it's the main reason why we always ask hard-working people to help us and send so many new flash fileas as possible and give to us so many new fopund pinouts as possible.
If each Infinity-Box "ChineseMiracle" user will find only 1 pinout and send to us we will be able to publish for all users all possible pinouts for all possible models.
N73, N72 chinese miracle Cable mod kaino147 Infinity-Box 8 06-15-2008 11:33
Chinese Miracle cable set, where?? armkbdotcom Infinity-Box 34 03-02-2008 11:45
<<<__N73 cable to use with the 29pcs chinese miracle cable?__>>> keaelite Infinity-Box 1 11-04-2007 11:25
Chinese Miracle Cables For Infinity,uni Box,ust-pro2,nspro,vygis,redbox,furious Gold paklink Main Sales Section 0 06-20-2007 18:39
Chinese Miracle cable set needed ASAP armkbdotcom Wanted Products 1 01-19-2007 02:55
Page generated in 0.28476 seconds with 10 queries
