03-08-2007, 11:13 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: tamilnadu, india.
Member: 243961 Status: Offline Sonork: 100.1591654 Thanks Meter: 104 | c168 "over temperature" while charging... is it hardware or the software fault.... when i try to charge the handset it says battery "Over voltage".. i changed the battery & charger .. still same condition... is it software fault... help me... thanks.... Last edited by harim_1981; 03-08-2007 at 11:28. |
07-11-2008, 04:34 | #2 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Faisalabad, Pakistan Age: 41
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | anyone have solution about this problem i have full clean change battery and charger but still same and in search not found solution so plz help urgent. Waiting for your kind response. Kind regards, Vicky |
07-12-2008, 15:26 | #5 (permalink) |
Member: 248050 Status: Offline Sonork: 100.1624328 Thanks Meter: 140 | this problem happen just as normal was working ok and charge ok than after low battery connect charger than it show over temerature not water damage and drop. another problem that some time it blink when power on and off and if press power button than it on and off some time on and working as normal and only charging fault remain. any idea? Kind regards, Vicky |
Many Samsung Phones Damaged By Hi Voltage While Charging Solution | dannyogolo | Samsung Hardware Repair | 47 | 02-25-2011 17:54 |
E330C shows "pause charging due to temperature" when charging | johnnytan | Samsung Hardware Repair | 5 | 03-16-2010 00:47 |
c168 "over voltage".. | harim_1981 | Motorola Hardware Repair | 1 | 08-28-2009 10:18 |
c168 full short because charging earea blast | shani72 | Motorola Hardware Repair | 2 | 02-23-2009 11:35 |
Help!Phone turns off while charging at 80%(after ME45 to ME45i). | Witek | x1x to x45/x50 | 2 | 10-20-2002 16:10 |
