Old 05-20-2008, 11:19   #1 (permalink)
Member: 403942
Thanks Meter: 8
Unhappy Cect E606 On Back Side .Software Is E550
Hi Friends i Got China Cect E606 With 1 sim accept and other not accept fault ..i try format with infinty and its dead .no eeprom backup was created.
i need its flash file
COM33 selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
eeprom backup enabled, it may takes several minutes !
Action: reset
Boot...
19200 fixed
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:26C1:00F2
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [enhanced] generation
security area#1 is Ok
security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.11F3B309.[E550_A5_E550_GPRS_MT6226_S01.01_2.BIN_48DC6894].rpl
New firmware detected:
- make "Read full flash" operation
- send "backup_system_log_..." file to support: [email protected]
- send flash backup file(s) to support: [email protected]
- include in your e-mail full text from phone back label (phone name etc.)
identification#1 detection finished
device-id: 11F3B309
identification#1 protocol ver: 04
ver. sw1: E550_A5_E550_GPRS_MT6226_S01.01_2.BIN
ver. sw2: E550_A5.01.2, 6B9723B7
ffs offset/size: 00800000/001FF000
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00800000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
Detected eeprom/ffs address is non-standard: 00E00000
Posible reasons:
1. eeprom is Ok but address is non-standard
2. eeprom damaged and can't be detected
3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure)
If you are not sure that detected address is correct:
1. press "NO" (and select standard address or terminate current operation)
2. make flash backup for emergency case
3. repeat required operation
Are you sure that detected eeprom address is correct ?
Do you want to use standard eeprom address: 00800000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
operation terminated by user
error: critical error#1 during ffs size detection
error: can't detect eeprom/ffs address/size
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _11F3B309_E550_A5_E550_GPRS_MT6226_S01.01_2.BIN_48 DC6894_20080518-182654.B0X.bin
Finished, time used: 84 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Now I need this flash file ..if any one have set please read full flash and give me ..thanks
E550_A5_E550_GPRS_MT6226_S01.01_2.BIN_48DC6894_200 80518-182654.B0X
how to know s/n if back side print is damage rafik2533 Z3X-Team Products 0 11-27-2009 06:05
ac on the back side? signo Cyclonebox 9 05-21-2009 11:23
SE K850i dead ( white keypad light on and blue ring of camera on back is on ) apnadesigns KULANKENDI Server 0 07-14-2008 05:31
Nokia6300 is fallen in water,after cleaning the when power on two light on the sides beneto Nokia Hardware & Hardware Repair 1 02-05-2008 07:11
on supporting Side BB Util is nt Avalible?? ~mr_Ten$ion~ FuriousGold 2 08-14-2006 11:50
Page generated in 0.18165 seconds with 10 queries
