Old 09-23-2008, 14:24   #1 (permalink)
Registered User
Member: 437195
Thanks Meter: 1,733
CECT i70
COM5 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection disabled
eeprom backup enabled, it may takes several minutes !
Action: "format ffs"
Boot...
baud autodetection active
19200 autodetect
Connecting, wait...
Initializing[6226:8A02:8A01]...
CPU: MT6226
high speed boot disabled
chip: 0031:A07D:A765
high speed disabled
boot step size: 0002
Release Power button now !
Boot Done
Initialize...
flash: FFFFFFFFFFFFFF:FFFFFF00000000
flash: AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
Warning: probably flash chip empty, erased, incorrectly flashed or damaged.
What to do:
1. go to software "Settings" page
2. set "Advanced chip detection method" box CHECKED !
3. make flash write operation
If still no luck: send mail to support ([email protected]) with detailed description of problem,
attach the next files in your e-mail:
1. C:\Program Files\InfinityBox\ChineseMiracle\operation.log
2. C:\Program Files\InfinityBox\ChineseMiracle\cfi_xxxx_xxxx.bin
it's time to stop: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
detecting firmware version...
can't detect firmware version
if software not respond/freez: make "Find firmware version (slow process)" unchecked and repeat operation.
detecting languages...
error: can't detect language parameter #1
can't detect language names
if software not respond/freez: make "Find language names (slow process)" unchecked and repeat operation.
Check firmware content Done
Backup required data...
reading: eeprom...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\eeprom_20080923-171235.B0E.bin
Backup required data Done
Patch required data...
Patch required data Done
Special operation...
Special operation Done
Write...
Write Done
Finalization...
formatting...
error: no any expected answer
error: flash erase error: 00E00000
error: erase #E2
Finalization Fail
Finished, time used: 348 sec
Remove/Install battery now !
Old 09-23-2008, 21:58   #2 (permalink)
Member: 148515
Thanks Meter: 15,876
hello!
this is a log of formating phone with damaged flash IC
veptu i70 firmware flash files mt6219at ..::UFUK26::.. Chinese Models & Cloned Phones 5 02-18-2009 16:39
CECT i70 dual sim pinout (not cect i70 veptu) glontz Infinity-Box 1 06-18-2008 18:46
hello plz help me how to made cable cect c1000 and cect n82 thanks doodeh Infinity-Box 4 10-21-2007 20:59
CECT W008 need flasher + flashfiles arielsat1 Chinese Models & Cloned Phones 0 06-10-2006 13:36
cect 818 with sws-sag??? SLIPLOCK ARM9 BASED M62 / M62+ 0 02-23-2006 00:47
Page generated in 0.20774 seconds with 8 queries
