03-10-2009, 11:24 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: THE END Age: 40
Member: 195225 Status: Offline Thanks Meter: 94 | 6300 rm-217 flight mode 7pin. ic 661u rm217 fcc id ppirm-217. im tested pinout 1 tx 2 rx and contraire gnd pin 4 thx for all |
03-10-2009, 11:53 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! are you sure that this is mt62xx MCU based phone? tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
03-11-2009, 22:00 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
6300 RM-217 v5.00 released | Hieng | Nokia Base Band 5 ( BB-5 ) | 26 | 02-13-2011 14:29 |
Unlock bb5 sucessfully 5610 rm-359,5310 rm-304,6300 rm-217 | topcomgsm | Cyclonebox | 9 | 05-04-2009 21:36 |
Firmware: 6300 RM-217 Version 5.50 | killer23d | Nokia Base Band 5 ( BB-5 ) | 0 | 10-11-2007 02:14 |
nokia 6300 rm-217 spnsion | CHAGUA | BB5BOX | 1 | 10-04-2007 05:38 |
