09-01-2008, 05:12 | #1 (permalink) |
Junior Member Join Date: Nov 2007
Member: 625150 Status: Offline Thanks Meter: 1 | cect q86 flash file required i had format cect q86 model but set is dead after formatting complete discription is below Device: Autodetect 6205-6227 NOR Done WARNING ! Settings will be cleared, user data erased, Imei set to default value ! Make flash backup before this procedure ! Do you want to continue ? COM3 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:AC2C94A high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.46271DE1.[E558_P2ARAB_E558_GPRS_MT6226_S01.01_1.BIN_22C91512].rpl ==================== New firmware detected: E558_P2ARAB_E558_GPRS_MT6226_S01.01_1.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== identification#1 detection finished device-id: 46271DE1 identification#1 protocol ver: 04 ver. sw1: E558_P2ARAB_E558_GPRS_MT6226_S01.01_1.BIN ver. sw2: E558_P2ARAB.01.1, EDEA36DD ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00800000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation operation terminated by user error: critical error#1 during ffs size detection error: can't detect eeprom/ffs address/size Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:29EA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\system_log_46271D E1_E558_P2ARAB_E558_GPRS_MT6226_S01.01_1.BIN_22C91 512_20080816-101653.B0X.bin Finished, time used: 189 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! plzzzzzzzzzzzzzzzzzzzzzz help me as soon as possible i also sent mail to infinity team but there is no reply |
09-01-2008, 09:50 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Did you tried to read text from log file ? Did you made a full flash backup before format operation ? Did you followed the next advice ? Code: ==================== New firmware detected: E558_P2ARAB_E558_GPRS_MT6226_S01.01_1.BIN - make "Read full flash" operation - send "backup_system_log_..." file to support: [email protected] - send flash backup file(s) to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) ==================== |
sendo flash files required or free flash file link plz urgent | asif_ae | Multi-Box | 1 | 07-30-2009 23:50 |
CECT T3100 Flash File Required | Munir Memon | Infinity-Box | 3 | 10-08-2008 21:44 |
6120 chinese flash flash file required....help infinity team | sairat | Infinity-Box | 1 | 03-01-2008 13:11 |
CECT M1818 flash file | reaz.com | Infinity-Box | 0 | 09-20-2007 09:22 |
Urgently need CECT V90 Flash File | nishaon | Infinity-Box | 5 | 07-06-2007 22:08 |
