09-14-2007, 22:56 | #1 (permalink) |
Freak Poster Join Date: Sep 2002
Member: 15333 Status: Offline Thanks Meter: 1 | Cect s500 dead repaird succesfully by rpl file,thanks infinity Your client is up-to-date. Requesting RPL... RPL received Ok. delete: g:\Program Files\InfinityBox\ChineseMiracle\id.D0DAA9D4.[MY6226_PCB01_GPRS_MT6226_S01.DM200_V09_1_7_MTR_BT_ DL.BIN_23BBFC86].ask Finished: id.D0DAA9D4.[MY6226_PCB01_GPRS_MT6226_S01.DM200_V09_1_7_MTR_BT_ DL.BIN_23BBFC86].ask operation completed: 11:20:13 PM COM13 [VCP0] selected Device: Autodetect 6205-6227,6228 nor Checking data, wait... advanced flash detection active Action: read/check detailed information Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Check space... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 89880F00010001:89880F00000000 flash: Intel Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification, method #1... detection phase #1... detect device parameters finished structure: 2nd [enhanced] (or higher) generation warning: probably identification data damaged, power-on problem possible error: rpl file not found: g:\Program Files\InfinityBox\ChineseMiracle\id.D0DAA9D4._MY62 26_PCB01_GPRS_MT6226_S01.DM200_V09_1_7_MTR_BT_DL.B IN_23BBFC86_.rpl file saved: id.D0DAA9D4.[MY6226_PCB01_GPRS_MT6226_S01.DM200_V09_1_7_MTR_BT_ DL.BIN_23BBFC86].ask ASK file created Ok Probably identification data damaged, device id: D0DAA9D4 firmware version: MY6226_PCB01_GPRS_MT6226_S01.DM200_V09_1_7_MTR_BT_ DL.BIN_23BBFC86 RPL file must be in folder: g:\Program Files\InfinityBox\ChineseMiracle\ You can create RPL from ASK via client/server right now and press YES. Do you want to write RPL file now ? flash: 89880F00010001:89880F00000000 flash: 89880F00010001:89880F00000000 Write: rpl rpl write ok identification detection finished device-id: D0DAA9D4 protocol ver: 04 ver. sw1: MY6226_PCB01_GPRS_MT6226_S01.DM200_V09_1_7_MTR_BT_ DL.BIN ver. sw2: DM200.V09.1.7.MTR.BT.DL ffs offset/size: 00F00000/00100000 detecting eeprom area in 1 chip(s)... flash: 89880F00010001:89880F00000000 checking area[00000000]: 00000000-00FFFFFF... eeprom found near: 00F00000 Detected eeprom address is non-standard: 00F00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? Do you want to use standard eeprom address: 00E00000 ? If you are not sure that standard address is correct: 1. press "NO" and terminate current operation 2. make flash backup for emergency case 3. repeat required operation standard eeprom address[00E00000] confirmed by user detecting eeprom size... eeprom size: 00200000 eeprom chip: 00 eeprom area: 00000000:00E00000-00FFFFFF detection phase #3... .................................................. .............. done detecting structure pass 1... ................ detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... .................................................. ...... fat location can't be detected eeprom element #1 detection failed error: autodetection failed Finished, time used: 287 sec Remove/Install battery now ! |
09-22-2007, 13:28 | #4 (permalink) | |
No Life Poster Join Date: Feb 2004 Location: inside AFRICA
Member: 56157 Status: Offline Sonork: 100.1573682 Thanks Meter: 171 | pinout s500 Quote:
please can you upload working pinout for cect s500 with alot of thanks | |
09-22-2007, 14:59 | #5 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | Quote:
BR MUNEEB AKHTAR RAZA | |
09-22-2007, 18:19 | #6 (permalink) | |
bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 | |
09-26-2007, 14:17 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | You can download from Infinity-Box support area: CM_Cect-S500_FIREFLY_856.W04.52_FIREFLY_856_HW_Mar-3-2005 CM_Cect-S500_L3A4201.6.12.1.0T02M0712_M451A_L3A4201.1.0_M4 51A_YJG_V410_01_ML6227_HW_2006-07-31_16m_En_Vn_Cn CM_Cect-S500-O2S_M503T_D28_PCB01_GPRS_MT6227_S00.00_0_16m_En_Vn |
03-18-2008, 12:20 | #9 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 471557 Status: Offline Thanks Meter: 13 | pinout sir MUNEEB_AKHTAR_RAZA how about the 1.....12 pin cect s500 still same ....? thanx.... in advance.... |
09-25-2009, 19:15 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! here is example how to find correct flash file for flashing: http://forum.gsmhosting.com/vbb/showthread.php?t=499453 but first you must try to solve your problem by format FFS |
08-30-2010, 21:30 | #12 (permalink) |
Crazy Poster Join Date: Apr 2005 Location: my live in hungary
Member: 138071 Status: Offline Thanks Meter: 3 | cect n5 help infinity! I have cect n5 and lost security backup! And phone not power on. this is: warning: unknown rom info structure: 3188_PCB01_GPRS_MT6235B_S01.ZZT_G3188TP01_5_0T20D0 106_MB01.BIN_1ED7994A Unknown firmware detected (v.3.20, database date: 20.08.2010), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: 3188_PCB01_GPRS_MT6235B_S01.ZZT_G3188TP01_5_0T20D0 106_MB01.BIN - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== error: startup code area #1 can't be fixed You can flash phone now but can not finalize it, in most cases phone CAN NOT power-on. Do you want to continue anyway ? aborted by user error: last error: 03E8:S_STOP Disconnect... done Finished, time used: 1 min 12 sec HElp need ask/rpl file .please help |
n95 8gb sd repaird succesfully, thx to hasnain | .:M@ster:. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 24 | 02-20-2010 20:38 |
PLZ TEAM INFINITY CECT s500 FLASH FILE | MANDEEP80104 | Infinity-Box | 4 | 06-24-2008 06:50 |
Cect C600 Flashed 100%% thanks infinity | .::KHURRAM::. | Infinity-Box | 2 | 12-05-2007 08:53 |
cect S500 pin out. pls help infinity team | HEDEF_GSM | Infinity-Box | 1 | 06-20-2007 11:55 |
