10-07-2008, 16:27 | #1 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Pakistan
Member: 243167 Status: Offline Thanks Meter: 14 | CECT T3100 Flash File Required plz give me a file of this modle chine CECT T3100. file name is: ( LC6223_07A_PCB01_GPRS_MT6223_S00.LKA8D01_07_36_1_3 T04M0118_M511B.BIN ) Thanks Munir Memon |
10-07-2008, 21:13 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! we dont have any other files than on support site. isnt it is a second MCU firmware? are you sure thath you need it? maybe it worth to focus on first MCU? |
10-08-2008, 12:59 | #3 (permalink) |
Member: 243167 Status: Offline Thanks Meter: 14 | Sir: i am shure and i send you log opration file for your information so kindly send me this file. Thanks Opration file: ==== log: [10/5/2008 7:33:04 PM] ==== COM4 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: "format ffs" Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6223:8A04]... CPU: MT6223 high speed boot enabled chip: 0011:3400:000C boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb detecting chip #01 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb detecting chip #01 in region #00... flash: 01227E22212201:2AEA0000000000 flash: Amd AMD/Fujitsu std [def 0080x020000] 16Mb it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: LC6223_07A_PCB01_GPRS_MT6223_S00.LKA8D01_07_36_1_3 T04M0118_M511B.BIN ver. sw2: LKA8D01.07.36.1.3T04M0118_M511B, 00000000 ffs offset/size: 00C40000/003C0000 detect device identification#2... detection phase #1... . warning: optional information is not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00C40000 flash: 01227E22212201:2AEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00D20000 Detected eeprom/ffs address is non-standard: 00D20000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00D20000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 002E0000 ffs chip: 00 eeprom/ffs area: 00000000:00D20000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Fail Finished, time used: 53 sec Remove/Install battery now ! follow this and reply me your many thanks Munir Memon |
sendo flash files required or free flash file link plz urgent | asif_ae | Multi-Box | 1 | 07-30-2009 23:50 |
cect q86 flash file required | unique.mobile | Infinity-Box | 1 | 09-01-2008 09:50 |
6120 chinese flash flash file required....help infinity team | sairat | Infinity-Box | 1 | 03-01-2008 13:11 |
CECT M1818 flash file | reaz.com | Infinity-Box | 0 | 09-20-2007 09:22 |
Urgently need CECT V90 Flash File | nishaon | Infinity-Box | 5 | 07-06-2007 22:08 |
