08-28-2008, 07:59 | #1 (permalink) |
Freak Poster Join Date: Dec 2007
Member: 655997 Status: Offline Thanks Meter: 9 | cect t688+ how to flash the pin out given by infinity,, i cant understand where is rx/tx.. do ihave to use cable if yes what set of cable... this is the pin out: keyboard top 1.........12 4: USB D+ 5: USB D- 8: Gnd 12: USB +V as i said im new with infinity specially flashing chinese phone..regards |
08-28-2008, 14:00 | #2 (permalink) | |
No Life Poster Join Date: May 2008 Location: COME & MADE GREEN WORLD
Member: 771937 Status: Offline Sonork: 100.1605717 Thanks Meter: 1,052 | Quote:
The Following User Says Thank You to debmobile For This Useful Post: |
08-28-2008, 14:44 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! first of all lets clear if this is MT62xx MCU based phone. For doing this without disassembling phone just type on phone keyboard *#0044# and then push green (send) button. if you will see "language set: english"- it is mt62xx |
08-29-2008, 02:44 | #5 (permalink) |
Member: 655997 Status: Offline Thanks Meter: 9 | yes mate the phone is mt62xxx base phone coz i opened the phone...the phone is dead...i want to know how to rvive it and what cable to use or if there is a pinout coz on the board there is no rx /tx indicated..thnksss |
08-29-2008, 02:50 | #6 (permalink) | |
Member: 655997 Status: Offline Thanks Meter: 9 | Quote:
more power to infinity team | |
08-29-2008, 08:07 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! first of all pinout mentioned in the beggining of tread is USB pinout for spreatrum phone. second: I have only found pinouts for CECT T688 with 18pin connector and 2x5 connector. this means that you have to find pinout yourself. this is easy procuedure, please follow it: 1. make sure that phone battery is charged enought 3,7volts or more 2. set multimeter to voltage measuring. 3. set one multimeter probe to sone grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx here is little example that this can be done easyly: http:///vbb/showthread.php?t=585463 Once you find 2 pins (tx, rx) with needed voltages please reffer to this tutorial: http://forum.gsmhosting.com/vbb/showthread.php?t=386780 make cable and do only one operation "read detailed information" post log here IF anything is not clear enough, please ask here i will help Last edited by InfinityHelp; 08-29-2008 at 08:14. |
08-29-2008, 08:50 | #8 (permalink) |
Member: 655997 Status: Offline Thanks Meter: 9 | @ infinity help thats a great answer i have to try it for myself first...that is exactly what i want to hear...thanks for the answer it was very much explained... wbr kevin182029 |
08-12-2009, 09:11 | #9 (permalink) |
Insane Poster Join Date: Nov 2006 Location: bangladesh, mymensingh.
Member: 400037 Status: Offline Thanks Meter: 11 | plase help me cect t688 ti chips flashe problem . [email protected] |
how to flash a52? | fuadgsm | E-Gold Based Phones | 1 | 03-29-2010 18:48 |
How to flash SGH B520.-URGENT- | prashantvrm | Samsung Flashers, Software, Firmware. | 1 | 03-29-2010 13:24 |
how to flash e250i | adda2004 | Samsung Flashers, Software, Firmware. | 0 | 03-29-2010 12:26 |
Cect Q380 How To Flash | kumar_pvj | Infinity-Box | 8 | 07-01-2008 08:09 |
How to flash CECT U8800 ? | Ibn'arabi | Infinity-Box | 9 | 10-09-2007 08:10 |
