Old 01-31-2008, 18:34   #1 (permalink)
Member: 445282
Thanks Meter: 28
cect t689 2 sim problem
cect t689 2nd sim error,after write imei with mode-3 using rx-b,tx-b, still same problem.pls help infinity team.
Old 02-01-2008, 02:47   #2 (permalink)
Member: 148515
Thanks Meter: 14,904
hello!
what kind of problem?
both phone IMEIs are ok now?
did you try to format second MCU flash?
Old 02-01-2008, 03:17   #3 (permalink)
Member: 445282
Thanks Meter: 28
put sim in A it works,sim in b it works, if put 2 sims at A slot and B slot at a time, the 2nd sim b error,how to check both phone imei,when i try to format second mcu infinity can't detect(using rx-b,tx-b,gnd.)
Old 02-01-2008, 03:31   #4 (permalink)
Member: 148515
hello!
*#06# what you see?
Old 02-01-2008, 15:55   #5 (permalink)
Member: 67805
Thanks Meter: 342
I have same phone problem. I repair both imei (second with tx-b rx-b) but problem still exist.
I dont know procedure to format second cpu thry tx-b rx-b??
br.
Old 02-01-2008, 18:11   #6 (permalink)
Member: 445282
Thanks Meter: 28
*#06# shows only one imei.
Old 02-02-2008, 07:27   #7 (permalink)
Member: 217398
t689 solution
hi this i have try in many sets it work try in complete mode
Old 02-02-2008, 11:40   #8 (permalink)
Member: 67805
Thanks Meter: 342
@pratikk
Thanks
I format and secon cpu then repair imei, but problem is still there, error show on lcd.It catch both sim card network but I cant make calls.When I power off phone this error warning is on lcd and i must remove battery to power off phone. I try to flash but not help. I think is hardware problem.
Old 02-02-2008, 12:17   #9 (permalink)
Member: 67805
Thanks Meter: 342
sim1 work good, error make when I try to call from sim2
Old 02-20-2008, 11:54   #10 (permalink)
Member: 5778
Thanks Meter: 10
any help please i have the same problem with phones like this t689 !!!!!
Old 02-20-2008, 12:48   #11 (permalink)
Member: 583680
Thanks Meter: 47
@mangaman
Yesterday I repaired second CPU2 for 5 phones CECT T689 succesfully.I used imei write mode-3.Chinese miracle 2.28.Now after pushing *#06# I see both imei on screen like:
IMEI:135*********
IMEI:135******XXY
I can not remember what firmware and CPUs these phones have,but I can tell it later thgis evening.
Old 02-20-2008, 17:25   #12 (permalink)
Member: 583680
Thanks Meter: 47
@mangaman
Here is it -CECT T689 CPU2 imei mode-3
firmware- [E550AGENT_S2_E550_GSM_MT6205B_DN.01_6.BIN]
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: imei
imei write method: mode-3
new imei: 518462145654254
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6205:8B00]...
CPU: MT6205
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 8988C300010001:8988C300000000
flash: Intel Intel std [def 0008x002000 001Fx010000] 2Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
detecting chip #08 in region #00...
detecting chip #09 in region #00...
detecting chip #0A in region #00...
detecting chip #0B in region #00...
detecting chip #0C in region #00...
detecting chip #0D in region #00...
detecting chip #0E in region #00...
detecting chip #0F in region #00...
number of flash chip/regions detected: 10/01
Initialize Done
Set baud...
921600
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00200000
detect device identification#1...
detection phase #1...
detection phase #2...
detect device identification#1 finished
identification#1 protocol ver: 02
ver. sw1: E550AGENT_S2_E550_GSM_MT6205B_DN.01_6.BIN
ver. sw2: E550AGENT_S2.01.6, 00000000
ffs offset/size: 00190000/00070000
detect device identification#2...
warning: optional information not found
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00190000
checking area[00000000]: 00000000-001FFFFF...
eeprom/ffs found near: 00190000
detecting eeprom/ffs size...
eeprom/ffs size: 00070000
ffs chip: 00
eeprom/ffs area: 00000000:00190000-001FFFFF
reading [eeprom[E550AGENT_S2_E550_GSM_MT6205B_DN.01_6.BIN]]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E550AGENT_S2_E550_GSM_MT6205B_DN.01_6.BIN]_20080220-034053.B0E.bin
Identification Done
Manipulation...
2 step(s) required to finalize
Manipulation Done
Finalization...
Finalization Done
Write...
Write: eeprom
Write Done
Finished, time used: 55 sec
Remove/Install battery now !
Old 02-20-2008, 18:02   #13 (permalink)
Member: 583680
Thanks Meter: 47
ps.
pinout for CPU2 cect T689:
CPU2
18-gnd
9-Tx(2.74v)
13-Rx(2.81v)
cect t689- 2-nd sim not working vali1971ro Chinese Models & Cloned Phones 0 12-18-2008 20:40
which is problem cect t689 dual sim genci titi 2002 Infinity-Box 4 07-02-2008 09:05
Cect T689 Dual Sim ...auto Off gidanz Infinity-Box 18 09-11-2007 20:59
CECT T689 dual sim PDA Phone crvkva10 HTC & PDA WM( With Touchscreen) 1 07-12-2007 09:31
Page generated in 0.41800 seconds with 9 queries
