08-13-2007, 09:46 | #3 (permalink) | |
Freak Poster Join Date: Feb 2004 Age: 44
Member: 53457 Status: Offline Thanks Meter: 9 | @InfinityHelp connector like samsung 18pin 1,2 pin are @InfinityHelp connector like samsung 18pin 1,2 pin are ground but one and mean thing is its shows info with usb in usb cabel 11 and 12 pin are rx, tx and pin 16, 17 , 18 for usb supply now 345678910pins are free try to find rx and tx in it Quote:
best regards cellworld | |
08-13-2007, 13:04 | #4 (permalink) |
Freak Poster Join Date: Jun 2007
Member: 525784 Status: Offline Thanks Meter: 8 | YES YOU RIGHT BUT : I HAVE one set of nec.com 1000 with 18 pin connector in usb cable i see pin 1 and 2 are GND and 16,17,18 are V-charge and 11,12 for tx and rx now i made cable for it connect rg45 pin7,8 to pin1,2 in phone . connect rj-45 pin 2 to phone pin 11 . connect rj-45 pin3 to phone pin12 . phone not boot and detect with infinity . change rx,tx in phone pin(pin11,12 ) but same result . i don't knbow what should i do ( |
08-13-2007, 18:33 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello black snake! how do you know that 11, 12 is comport pins? If you trace oroiginal USB cable- then you got wrong pins. because pins which are used for USB connection can not be used for serial. |
08-13-2007, 23:19 | #6 (permalink) |
Member: 525784 Status: Offline Thanks Meter: 8 | WOWWWWWWWWW thus we have this : 1 = GND 2 = GND 3 = ? 4 = ? 5 = ? 6 = ? 7 = ? 8 = ? 9 = ? 10 = ? 11 = USB DATA + 12 = USB DATA - 13 = ? 14 = ? 15 = ? 16 = VCC 17 = VCC 18 = VCC HOW SHOULD WE FIND TX, RX PIN FROM THIS " ? " |
08-14-2007, 08:00 | #7 (permalink) | |
Member: 53457 Status: Offline Thanks Meter: 9 | @black snake hi dear i have same phone for same pro @black snake hi dear i have same phone for same problem i cant get success to find rx and tx for com Quote:
cellworld | |
08-14-2007, 20:15 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! cant find anything similar to this pinout in our database. you can try to find pinout by yourself: solder to all free conacts wires, other wire side to IC socet. use needles to connect tx, rx to all pins one by one. with use of IC socet you dont need soldering to change pins, this is very convinient. with 11 free contacts it gives just 110 combinations. you can try all in 20minutes. this is regular way how i find pinouts |
08-14-2007, 22:01 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! set first combination of Tx , Rx and push "read flash". program will ask you to power On phone. you press and hold power button. If all ok- program will start reading. if Not- phone will power On. remove battery set it back, set next combination of TX, Rx and try again until you connect succesfuly |
08-14-2007, 22:51 | #12 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Quote:
08-15-2007, 05:50 | #13 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Quote:
i need cect t689 pinout please | shama | Chinese Cocktail | 2 | 01-08-2008 13:41 |
Cect T689 pinout | 468492DF | Infinity-Box | 1 | 01-02-2008 20:35 |
cect t689 pinout plzzzzz | firrozkhan_00 | Chinese Models & Cloned Phones | 1 | 10-31-2007 10:03 |
cect t689 pcb pinout | dan1gsm | Infinity-Box | 5 | 10-07-2007 13:30 |
cect t689 pda pinout | 5mobile | Infinity-Box | 2 | 08-24-2007 17:47 |
