Old 11-14-2007, 21:26   #1 (permalink)
snsoftkiller's Avatar
Member: 250468
Sonork: 100.110362
Thanks Meter: 90
CECT T689 says "ERROR" and second sim mot solved
Hi,
My CECT T689 second sim not solved, phone display "error" when power off.
I try complete format and format ffs for both cpu still same.
Here I post log of 2nd cpu flash !!!
COM7 [VCP1] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
advanced flash detection active
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6205:8B00]...
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E221A2200:101C0E00000000
flash: Amd AMD/Fujitsu std [B 0008x002000 003Fx010000] 4Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud...
115200
Set baud Done
Identification...
device parameters autodetection in progress..
it's time to stop: 10680E1C01781F1C022905D128490978022901D10020F8BD
total flash region size: 00400000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-003FFFFF...
Can't detect eeprom area
Do you want to use standard eeprom address: 00380000 ?
If you are not sure that standard address is correct:
1. press "NO" and terminate current operation
2. make flash backup for emergency case
3. repeat required operation
standard eeprom address selected by user
detecting eeprom size...
eeprom size: 00080000
eeprom chip: 00
eeprom area: 00000000:00380000-003FFFFF
reading [eeprom]...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom_20071114-201205.B0E.bin
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
detect device identification, method #1...
detection phase #1...
detection phase #2...
warning: identification information not found, possible reasons:
.old firmware type w/o identification data
.damaged firmware
.damaged hardware
detect device parameters finished
Area: Firmware
Write: Firmware
protocol ver: 02
ver. sw1: E550AGENT_S1_E550_GSM_MT6205B_DN.01_5.BIN
ver. sw2: E550AGENT_S1.01.5
ffs offset/size: 00E00000/00200000
Write Done
Finished, time used: 704 sec
Remove/Install battery now !
Old 11-17-2007, 23:28   #2 (permalink)
Member: 236667
Thanks Meter: 6
The second CPU should never be flashed! I said not once...the second cpu is a parasite one: in that second flash ic there are only the basic algo,RF data data and startup software.The operating software(if second sim is detected) is obtained from main flash ic.And this china units they are newer the same so the basic content may and usually is different.The solution to your problem is write back up,if you made one... The solution to second sim problem is : format full then write imei(from the back label).If it`s not working it can be hardware problem(sim reader error,Bluetooth malfunction and RF ic)
Old 12-10-2007, 21:26   #3 (permalink)
xacker's Avatar
Member: 19027
Thanks Meter: 5
T689 error
please help my cect T689 for off fone mesiging ERROR
Old 12-10-2007, 21:33   #4 (permalink)
Member: 148515
Thanks Meter: 14,904
hello xacker!
format ffs for both parts, write imei if needed
Old 12-12-2007, 12:18   #5 (permalink)
Member: 97553
Originally Posted by SNSOFTKILLER View Post
Hi,
write: Firmware
skip: Customization
skip: Language Pack
skip: Eeprom
Boot...
19200
Connecting, wait...
Boot Done
Initialize...
Initialize Done
Set baud...
115200
Set baud Done
Identification...
eeprom chip: 00
reading [eeprom]...
Identification Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
.damaged firmware
.damaged hardware
Area: Firmware
Write: Firmware
protocol ver: 02
Write Done
can you please give me the detail pinout you use for the format. I also have the same problem but i do not have the pinout to connect to the software
Old 12-12-2007, 12:28   #6 (permalink)
Member: 250468
Sonork: 100.110362
Thanks Meter: 90
Search in forum there is a picture already posted for pinouts.
Old 12-12-2007, 13:19   #7 (permalink)
.::BHATTI::.'s Avatar
Member: 203158
Sonork: 100.1592032
Thanks Meter: 358
did u tried IMEI change...............fro second CPU???
Old 01-10-2008, 01:10   #8 (permalink)
Member: 37317
Thanks Meter: 8
hi, did you solve the problem , 'couse I have two pieces with same problem here- "Error " message appears when turning the phone off. I already formatted both FFS, fullflashed first and second CPU( readed flashes from completly working handset), rebuild both IMEI's but the problem still persist.
Any ideas are welcome
b.r
Old 01-10-2008, 01:13   #9 (permalink)
Member: 250468
Sonork: 100.110362
Thanks Meter: 90
b.r
Was nit solved, customer take the phone
But try to remove bluetooth IC (samsung labeled IC) and post result.
Old 02-12-2008, 03:45   #10 (permalink)
Member: 67805
Thanks Meter: 342
I can't make "complete format" on second cpu useing tx_b rx_b because always I get "error writeing at address..." at first address. Also I can make backup of eprom but I can't write to phone because of same error. I try every sugestion by Infinity soft, and I try every other option like lower baudrate and...
Second sim don't work at all. First sim is ok and I make repair of imei
Could be this a hardware problem? and what action to take?
Old 02-12-2008, 10:20   #11 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,062
U NEED TO AGAIN FORMET RXb TXb POINTS
br
MAPLE GSM(UMER)
Old 02-12-2008, 10:48   #12 (permalink)
Member: 67805
Thanks Meter: 342
br
MAPLE GSM(UMER)
Read me carefully!!!
Old 02-12-2008, 21:28   #13 (permalink)
Member: 148515
hello MOBICOM!
hard to say without seeing log file...looks like flash hardware fault.
may i see log file with writing/formating error?
Cect T689 flash ...dual sim alunecosu_hd Infinity-Box 7 02-23-2010 21:20
T689 second sim is going off zoki Infinity-Box 40 05-01-2008 17:22
Problem with Second mcu(SIM B) for CECT t689????? salim00dz Chinese Cocktail 32 04-17-2008 10:02
cect t689 second sim tenma Infinity-Box 1 01-05-2008 19:03
CECT T689 dual sim PDA Phone crvkva10 HTC & PDA WM( With Touchscreen) 1 07-12-2007 09:31
Page generated in 0.44230 seconds with 8 queries
