03-25-2008, 16:59
#3 (permalink)
Member: 332978
Thanks Meter: 59 | help me please imei rebuild error Quote:
COM25 [VCP0] selected
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: imei
imei write method: mode-3
new imei: 350448011234561
Boot...
19200 fixed
Connecting, wait...
Initializing[6205:8B00]...
CPU: MT6205
high speed boot enabled
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 01227E221A2201:18E59F00000000
flash: Amd AMD/Fujitsu std [T 0008x002000 003Fx010000] 4Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
detecting chip #04 in region #00...
detecting chip #05 in region #00...
detecting chip #06 in region #00...
detecting chip #07 in region #00...
number of flash chip/regions detected: 08/01
Initialize Done
Set baud...
460800
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 00400000
detect device identification#1...
detection phase #1...
detection phase #2...
warning: identification#1 information not found, possible reasons:
.old firmware type w/o identification#1 data
.damaged firmware
.damaged hardware
if phone works fine just ignore this warning
detect device identification#1 finished
detect device identification#2...
warning: optional information not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset assigned: 00380000
checking area[00000000]: 00000000-003FFFFF...
eeprom/ffs found near: 00380000
detecting eeprom/ffs size...
eeprom/ffs size: 00080000
ffs chip: 00
eeprom/ffs area: 00000000:00380000-003FFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading [eeprom]...
warning: wrong data size at 0x003D9000, retry...
error: too many retries during read operation
Probably errors exist during flash read operation.
Do you want to repeat read operation ?
error: wrong answer: 3B
error: wrong answer: C3
operation canceled by user
error: no any expected answer: wrong answer after chip id request
error: no any expected answer: wrong answer after chip cfi request
Backup required data Done
Patch required data...
imei is not detected !
What to do:
1. Power-On phone
2. wait 20-30 sec
3. Power-Off by "Power" button, don't remove battery !
4. Repeat "imei repair" procedure again
If imei can't be detected:
1. make "complete" ffs format
2. Power-On phone
3. wait 20-30 sec
4. Power-Off by "Power" button, don't remove battery !
5. Repeat "imei repair" procedure again
If imei can't be detected: read flash and send to support: [email protected]
Patch required data Fail
Finished, time used: 141 sec
Remove/Install battery now !
