02-01-2008, 22:05 | #1 (permalink) |
Freak Poster Join Date: May 2006
Member: 281925 Status: Offline Sonork: 100.113915 Thanks Meter: 63 | cect v180 restarting problem but after ffs same problem i do ffs complite but phone have same problem phone have two cpu and connact with rx1 tx1 not connact with rx2 tx2 how to do ? |
02-02-2008, 21:12 | #3 (permalink) | |
Member: 281925 Status: Offline Sonork: 100.113915 Thanks Meter: 63 | Quote:
i meen does't work with one card and is there any solution to format spread cpu phone bcoz i test in more then 10 sets infinity box not detact phone why ? | |
02-03-2008, 14:39 | #6 (permalink) |
Member: 281925 Status: Offline Sonork: 100.113915 Thanks Meter: 63 | now succsesfully repaier cect v180 dual cpu phone after flash now succsesfully repaier cect v180 dual cpu phone after flash here log Code: ==== log opened: [2/3/2008 6:27:52 PM] ==== Application: C:\Program Files\InfinityBox\ChineseMiracle\ChineseMiracle.exe Loading data, wait... [Infinity Box] v2.24 S/N: :D:D:D:D:D:D Wait... Device: Autodetect 6205-6227 NOR Done Loading file v.02... CM_Cect-V180-2sim_E553_KT3F8C_E553_GPRS_MT6226_S01.01_1_16m_En_Ru_Fr_Es_De_Th_Vn_Tr_Ar.B0M.bin loaded identification#1 protocol ver: 04 ver. sw1: E553_KT3F8C_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_KT3F8C.01.1, B384BCA2 You have loaded file with security features enabled. Languages: En Ru Fr Es De Th Vn Tr Ar COM5 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization skip: Language Pack skip: Eeprom/ffs Boot... Press and HOLD Power button now ! baud autodetection active 19200 Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 chip: 0031:DF00:5A84 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Identification... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.DFE42F46.[E553_KT1C_E553_GPRS_MT6226_S01.01_1.BIN_D3437A28].rpl identification#1 detection finished device-id: DFE42F46 identification#1 protocol ver: 04 ver. sw1: E553_KT1C_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_KT1C.01.1, D785BC2C ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF reading [eeprom[E553_KT1C_E553_GPRS_MT6226_S01.01_1.BIN]]... file saved: C:\Documents and Settings\MODIATOR\Desktop\gunjan\backup_eeprom[E553_KT1C_E553_GPRS_MT6226_S01.01_1.BIN]_20080203-183454.B0E.bin flash: EC257E25082501:29EA0000000000 Identification Done Manipulation... Manipulation Done Finalization... Finalization Done Write... detect device identification#2... detection phase #1... . warning: optional information not found detect device identification#2 finished security area#1 calculation... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log_DFE42F46_E553_KT1C_E553_GPRS_MT6226_S01.01_1.BIN_D3437A28_20080203-183505.B0X.bin Area: Firmware flash: EC257E25082501:29EA0000000000 Write: Firmware Write Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log_DFE42F46_E553_KT1C_E553_GPRS_MT6226_S01.01_1.BIN_D3437A28_20080203-184048.B0X.bin Finished, time used: 635 sec Remove/Install battery now ! Code: CM_Cect-V180-2sim_E553_KT3F8C_E553_GPRS_MT6226_S01.01_1_16m_En_Ru_Fr_Es_De_Th_Vn_Tr_Ar.B0M.bin [new] |
02-03-2008, 14:45 | #7 (permalink) |
Member: 281925 Status: Offline Sonork: 100.113915 Thanks Meter: 63 | i done ffs by E$ box [restarting] Spider$$$ box [display not showing any icon meen phone start but whit light ] and also infinity box [still restarting ] then after flash phone work well thx to akhil ray for best support |
03-15-2008, 16:48 | #9 (permalink) | |
Please, check: http://www./showthread.php?t=513540 | |
05-09-2009, 02:06 | #10 (permalink) |
Junior Member Join Date: Nov 2008 Location: Bamberg, Bavaria, GERMANY
Member: 904681 Status: Offline Thanks Meter: 0 | Cect V180 FlashFile? Where 2 get it? Hello everybody... Please, where can I get those file?: CM_Cect-V180-2sim_E553_KT3F8C_E553_GPRS_MT6226_S01.01_1_16m_En_ Ru_Fr_Es_De_Th_Vn_Tr_Ar.B0M.bin If somebody would give me an active link (maybe a newer/better file for this phone) for downloading this file would be pretty fine. Oh... I'll buy a USB unlocking/flashing cable just 4 that phone. So there is everything I need (Box inbetween the cable). If those file doesn't work with "freeware" (and without any flash-boxes), please let me know a functional file-link... I'll pay a beer (sorry, just virtual) for the uploader Thanx a lot |
Sigmatel restart with sim after ffs etc. | Riteshgpt60 | Infinity-Box | 25 | 04-17-2010 11:24 |
N88 Restarting after Format same problem.. | ASHRIFF | Infinity-Box | 8 | 04-23-2008 11:32 |
Cect V180 Format OK But Same Problme !!!! | kalpeshoza | SpiderMan | 5 | 03-19-2008 05:03 |
CECT V180 restart | manyosa | Chinese Cocktail | 8 | 12-08-2007 11:58 |
Anycool D66 After Ffs Same Problem | jothi737 | Infinity-Box | 2 | 11-11-2007 13:11 |
