Old 10-16-2008, 20:20   #1 (permalink)
Member: 777880
Cect V329 - cannot detect pin with Pin-finder
I'm trying to detect pins with pin-finder in order to read rom but pinfinder continually fails to detect pins! It is a Chinese phone.
You can have a look of it here:
http://www.youtube.com/watch?v=wRO_b9hvRWs
Can somebody help?
Old 10-17-2008, 17:09   #2 (permalink)
Member: 777880
Anybody?? Infinityhelp please help! Why is the phone not recognised?
Old 10-20-2008, 19:00   #3 (permalink)
Member: 777880
Can somebody help?
Why is this phone not recognised by pinfinder?
Old 10-20-2008, 20:33   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,485
Hello,
Did you tried to find RX and TX at phone PCB ?
Did you tried to set \"Finder activation tries\" value to 15 or 20 ?
Old 10-20-2008, 20:54   #5 (permalink)
Member: 777880
Originally Posted by InfinitySupport View Post
Hello,
Do I have to open the phone to do this? I haven't done it before.
No, I didn't. Will it change something?
Old 10-21-2008, 10:12   #6 (permalink)
Member: 148515
Thanks Meter: 16,268
hello!
sometimes, if pinout can not be found, you must set "activation tries" to greater, then default value. for example from my experience: iFOE P168i Finder activation tries below 10 (i had 7) did not detect pinout
Old 10-21-2008, 20:41   #7 (permalink)
Member: 777880
hello!
I tried every single method (even 20 activation tries) but it still fails.
Any other suggestion?
Old 10-21-2008, 22:04   #8 (permalink)
Member: 148515
hello!
is this phone is based on MT62xx MCU ?
maybe it is spreadtrum or else?
Old 10-21-2008, 22:12   #9 (permalink)
Member: 777880
hello!
When connecting to USB while phone is switched on, I choose webcam mode and PC recognises it as 6225. Thus, it must be MT62xx CPU.
I tried other CPUs in LPE as well just in case with no success.
Old 10-21-2008, 23:14   #10 (permalink)
Member: 148515
hello!
in this case this means that this phone doesent hold tx/rx in system connector
Old 10-21-2008, 23:25   #11 (permalink)
Member: 777880
hello!
So you mean that there is no way to detect pinout?
Old 10-22-2008, 15:44   #12 (permalink)
Member: 148515
hello!
you must disassemble phone and look for test points.
take open cable from pinifnder and solder all wires to those test points.
which colur goes to which test point- is not important.
attach battery, run pinout search again
Old 10-22-2008, 17:33   #13 (permalink)
Member: 777880
hello!
Hello!
Which one is the open cable?
Is it the open circuit that you mean (it is not actually a cable) ?
How will I recognise test points when I open the phone?
Are there any photo instructions or more details regarding this procedure somewhere?
Old 10-22-2008, 21:53   #14 (permalink)
Member: 148515
hello!
please post photo of your phone PCB, i will check if there is test points
Old 01-22-2009, 09:27   #15 (permalink)
C-Mobile's Avatar
Member: 64496
Thanks Meter: 74
pin out on pcb
COM13 [VCP0] selected
module v2.74
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot Off
chip: 0001:F503:0006
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: M.RR9012301.M28102.V1.1.0.0M0820
Version: REBOUND25_GEMINI_HW
detecting structure #2...
5 11 done
67 byte(s) read
imei: 35702001805999
connection Ok
building list...
done
items to clear: 181
warning: wrong packet cs
items cleared: 179 of 181
building list...
done
items remains: 0
Finished, time used: 39 sec
Remove/Install battery now !
The Following User Says Thank You to C-Mobile For This Useful Post:
Iphone cect q380 spreadtrum chips cannot detect with pinfinder MR.PRESIDENT Infinity-Box 9 11-05-2010 19:17
pin finder cannot detect my china n95 (opel M650) djloyd Infinity-Box 8 05-29-2009 20:55
it is possible to detect spreadtrum cpu with pin finder ? unlock & flash Infinity-Box 1 03-29-2009 21:00
*** Cannot Detect Em325 With Scout *** moni108 Scout 2 02-02-2009 09:42
cect q380 can't find pin outs with pin finder kiran Infinity-Box 4 04-09-2008 09:12
Page generated in 0.44857 seconds with 8 queries
