11-07-2007, 11:55 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Message of William Branham
Member: 239523 Status: Offline Thanks Meter: 210 | world first: 2nd sim prob solved after the 2 cpu are formated the phone imei will chenge. just power on phone and restore imei using rxa/txa for 1rst cpu imei and then restart phone and restore 2nd cpu imei (I use same imei like 1st cpu) using rxb/txb. now after this process ur phone is ok but when u check the imei u will see 2 imeis displayed but all 2 sims will work perfectly. questions now: in my case I use the same imei for the 2 cpu but it works because I used 2 simcards from 2 differents operator but could not test 2 simcard from same operator because csutomer hapilly took back his phone quickly. I don't know if it will work in case I use 2 simcard from same operator??? but u can simply put different imei in the 2nd cpu to solve this). now I think it is more clear. the new direction of our job now must be how to get the second cpu pinout for all other phone knowing that all our cables are only built for the first cpu access. big thanks from Burkina Faso to infinity team |
The Following 6 Users Say Thank You to bamogil For This Useful Post: |
11-07-2007, 12:28 | #2 (permalink) |
No Life Poster Join Date: Jul 2005 Location: France Age: 48
Member: 165812 Status: Offline Sonork: 100:1627635 Thanks Meter: 4,267 | great info here my friend but i have one Q: for TXb and RXb do they have connection to the phone's connector or u have to connect them on board?? |
11-07-2007, 12:42 | #3 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: China Age: 46
Member: 68392 Status: Offline Sonork: 100.100701 Thanks Meter: 658 | Read this man he write this. Quote:
11-07-2007, 13:49 | #4 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: Narnia Age: 44
Member: 236667 Status: Offline Thanks Meter: 12 | Quote:
11-07-2007, 14:03 | #5 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Quote:
Thanks for the solution !!!! @ndre 1st to post may be the step by step solution | |
11-07-2007, 14:15 | #6 (permalink) | |
Freak Poster Join Date: Dec 2005
Member: 205128 Status: Offline Thanks Meter: 18 | Old News Quote:
SO YOU THINK UR THE FIRST IN THE WORLD??????? | |
11-07-2007, 19:57 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello bamogil! thank you for sharing this step by step discription!!! i am sure it will save other people many time, i am adding this tread to FAQ section. regarding duble IMEI in same netowk- this can be different in different countrys. some countrys (like russia) do not check for double imei, some- check. you can get to know only by testing in own network |
11-08-2007, 00:41 | #11 (permalink) |
Freak Poster Join Date: Nov 2003 Location: jordan
Member: 44186 Status: Offline Sonork: 100.108965 Thanks Meter: 65 | and another Q . ... if i want to flash the second cpu , are flash files available at support .. or its just the same flashfile for cpu 1 .... this thread start to be for step by step discuttion ... hope we find usefull information on.. |
11-08-2007, 03:37 | #12 (permalink) | |
Firmware for 1st and 2nd CPU has difference due to in most cases first CPU is 6226 (6227) and 2nd CPU is 6205. So, backup files from 2nd CPU always welcome: [email protected] @bamogil Thank you very much ! Your instruction is very good and for sure it's really First In The World really good and clear description how to make this kind of work. | |
11-08-2007, 05:37 | #13 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | rxa/txa for first cpu and rxb/txb for 2nd cpu must be used for backup ...this is a nice solution appricate ur hard work |
11-09-2007, 10:17 | #15 (permalink) |
No Life Poster Join Date: Nov 2005 Location: TANZANIA Age: 47
Member: 202611 Status: Offline Thanks Meter: 51 | for me i have been recieving many 2sim card with txa and rxa, txb and rxb but always i have been using txa and rxa and all work fine was i doing wrong coz after formatting all do fine and customer a happy again was i doing wrong |
World First: SonyEricsson S1 Unlock Code by IMEI on UnlockBase.com | UnlockBase.com | Main Sales Section | 0 | 04-29-2009 10:22 |
N95 dual sim 2nd sim emrgency | BENCHENA | Infinity-Box | 8 | 09-21-2008 07:49 |
WORLD FIRST: Direct Unlock of new Samsung Trident Series ! | ssa | Main Sales Section | 0 | 02-09-2008 12:06 |
First in the World repair 2nd SIM problem in Chinese phones | InfinitySupport | Main Sales Section | 0 | 01-23-2008 19:05 |
WORLD FIRST: NEC 411i, E540, N500i, N412i, E949, E938, L1, N512i !!! | .:hack3r2k:. | Main Sales Section | 0 | 06-10-2006 23:17 |
