12-08-2007, 14:42 | #1 (permalink) |
Crazy Poster Join Date: Oct 2006
Member: 380368 Status: Offline Thanks Meter: 11 | CECT V90 White Light |
12-08-2007, 19:28 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Cable: Due to a lot of different models with the same name but absolutely different hardware (f.e. exist at least 5 phones with name "Chinese Nokia-N95" but different pinouts), bottom connectors and different pinouts we recommend you to include the next info: 1. detailed description of model 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 Repair: Infinity-Box "Chinese Miracle": How to repair "White LCD", "Black LCD", "no LCD" problems: 1. check phone hardware: LCD unit may be damaged. 2. check phone hardware: LCD flex cable may be damaged. 3. use other flash files for flashing, because exist many different phones with different LCD hardware types so need to use different firmware files and find firmware that work good for your LCD hardware. Select flash file with similar firmware version, phone model name is not important, only firmware version is important. |
12-08-2007, 20:02 | #3 (permalink) | |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | Quote:
does the phone send and recive calls? does it make a startup tone when you press the power, or it just hangs on white LCD? BR Mansi | |
12-09-2007, 06:27 | #5 (permalink) | |
1662 white light | kakey | Nokia Hardware & Hardware Repair | 10 | 03-30-2010 08:02 |
i have cect 818 white light !!! plz help | manish665 | SpiderMan | 0 | 10-05-2008 10:04 |
CECT V90 Restart Now Ok... | SHOEB AHMED | Chinese Cocktail | 3 | 10-19-2007 12:57 |
please help CECT V90......../// | SHOEB AHMED | Chinese Cocktail | 15 | 10-17-2007 19:01 |
Urgently need CECT V90 Flash File | nishaon | Infinity-Box | 5 | 07-06-2007 22:08 |
