02-10-2010, 08:15 | #3 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Iassy Age: 59
Member: 19723 Status: Offline Thanks Meter: 359 | When I try with mode-auto (after I saved full flash) the operation is successfull but the touch doesn't work . With all others it fails (the touch was working) . Thanx ! |
02-10-2010, 19:04 | #8 (permalink) | |
Why you can not calibrate it ? After format each phone with touchscreen should ask you to make manual calibration (click to each touchscreen corner several times). Do you see manual calibration questions when you power-on phone after format ? | |
02-22-2010, 15:30 | #15 (permalink) |
Member: 19723 Status: Offline Thanks Meter: 359 | COM4 [VCP0] selected module v3.09 Action: reset settings ("format ffs") Model: Autodetect 6228-6239 NAND Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF rom: 4D573031 Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6235,E04 Date: 2000.00.00 Version: 1.0 Version: E706_XZY1IPHONE.01.0 Version: EVEN35_08B_HW 87 byte(s) read imei: 60159980837630 connection Ok building list... done items to clear: 285 warning: wrong packet cs warning: wrong packet cs warning: wrong packet cs items cleared: 223 of 285 building list... done items remains: 0 Finished, time used: 5 min 10 sec Remove/Install battery now ! And complete format : COM4 [VCP0] selected module v3.09 Device: Autodetect 6228-6239 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.936.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M chip size: 64Mb page/spare size: 0200/0010 pages/block: 0020 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: absent done Set baudrate (921600)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 03000000/01000000 firmware size: 48Mb ffs size: 16Mb detect sec ro... detect custom parameters... detect project-id... project-id: E706_XZY1IPHONE.01.0 detect NAND info... number of areas to read: 1 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... external bootloader is not present bootloader version: E706_BOOTLOADER_V005_MT6235B_01_1.bin nfi area detection finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 05 sw version: E706_XZY1IPHONE_PCB01_GPRS_MT6235B_S01.01_0.BIN project-id: E706_XZY1IPHONE.01.0, 00000000 code offset: 00000000 ffs offset/size [01]: 03000000/01000000 rom info structure: 2nd [standard] generation TCL-ID is absent ===> done Format (HW_STORAGE_NAND)... Disconnect... done Finished, time used: 36 sec Remove/Install battery now ! |
CESIM V700 flash | usernome | Infinity-Box | 1 | 02-09-2010 20:57 |
Siroya SGC-V700 unlocking When? | haxbox | UST Pro II | 1 | 06-03-2007 08:22 |
SGC-V700 unlock? | haxbox | UST Pro II | 0 | 05-31-2007 04:58 |
Mpx 2000/v700 | foneworkshop | Smart-Clip | 1 | 02-01-2005 23:27 |
prodigy update to v700 build 10 "error 3" | mansi | Federal One | 2 | 03-09-2004 23:21 |
