06-05-2009, 05:13 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: miami Age: 47
Member: 112190 Status: Offline Thanks Meter: 21 | cesim v800 "set parameters to value 20 (or more) and repeat the operation (parameters "finder activation tries")" how to change these parameters???? that's what I got???? I already read some others chinesse phones so the system is working. but the V800 is not responding ,is there any trick for this phone??? thanks best regards linterna |
06-05-2009, 09:08 | #2 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: Chandigarh,India Age: 40
Member: 220603 Status: Offline Thanks Meter: 1,164 | Quote:
The Following User Says Thank You to deepakgarg For This Useful Post: |
06-05-2009, 10:59 | #3 (permalink) | |
At first you need to know what is phone CPU chip name. If you can not detect pinout in automatic mode you need to open phone and check what is CPU chip name. | |
06-18-2009, 13:38 | #6 (permalink) |
Major Poster Join Date: Jan 2003 Location: Ukraine, Kharkiv Age: 43
Member: 20554 Status: Offline Thanks Meter: 1 | Hi All, linterna1, your CPU is MT6235 here is cable pinout: count pins when you look on connector from left to right 8 - Тx 9 - Rx 17+18 - GND you can use FlashTool_v3.0840.00 or newer to read\write flash set operations method NFB there are 2 firmware vesions i know last X8_XZY_MLB_1_7T08S0309 2009/03/09 master full can be found here http://rapidshare.com/files/23600470..._Pavel.7z.html to update firmware you need to load scat_6235_Pavel.txt (Scatter-loading ) after flash make reset for factory settings password 1122 |
The Following User Says Thank You to KSAT For This Useful Post: |
CESIM V800 touch problems | nina83 | Chinese Models & Cloned Phones | 9 | 03-25-2010 18:33 |
Cesim v800 help | TOMMY1977 | Chinese Models & Cloned Phones | 0 | 06-25-2009 21:45 |
cesim v800 applications | TOMMY1977 | Chinese Models & Cloned Phones | 0 | 06-21-2009 13:04 |
Cesim v800 | TOMMY1977 | Chinese Models & Cloned Phones | 0 | 06-16-2009 13:47 |
Cesim V800 Dual SIM Card Phone with Analog TV & Bluetooth | IPMART | ipmart WebShop | 0 | 02-06-2009 09:40 |
