Old 12-15-2009, 15:54   #1 (permalink)
Member: 300690
Thanks Meter: 12
Challenging problem to infinity
hello infinity team i all ready asked u this question but no proper reply.again iam asking question brieflyyy.please try to solve my problem.
firts of all some models like N958,,P11,M99... few models have a imei which displays with #06#.and another imei inside the firmware(#2imei).
usually i do for #2imei with mode 1.but for these models when i use mode 1.software shows like in the image.
and when i use mode 2.than also software changes #1 imei.log is below
COM5 [VCP0] selected
module v3.02
Action: imei
imei write method: mode-2
imei write channel: imei #2 for dual sim/mono CPU
new imei: 353923030847095
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:9203:0004
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6225,E03
Date: 2006.06.14
Version: 1.0
Version: E880_EVTST.01.0_25S00
Version: EVEN25_HW
detecting structure #2...
0 done
44 byte(s) read
imei: 35944402563794
connection Ok
0 done
44 byte(s) read
verification...
verification done: 35392303084709
Finished, time used: 25 sec
Remove/Install battery now !
and finally i used the option ""#1imei(defualt imei inside the firmware)than the log is
module v3.02
Device: Autodetect 6205-6227 NOR
Action: "repair imei"
imei write channel: imei #1 (default imei inside firmware)
new imei: 357988021566448
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6225
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
115200
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
New firmware detected (v.3.02, database date: 03.12.2009):
E880_MY1MCF10_E880_GPRS_MT6225_S00.01_2.BIN
This firmware is missing in support area. If this phone is good and working:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
rom info protocol ver: 04
ver. sw 1: E880_MY1MCF10_E880_GPRS_MT6225_S00.01_2.BIN
ver. sw 2: E880_MY1MCF10.01.2, 00000000
code offset: 00000000
ffs offset/size: 00E00000/001FF000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
detecting startup code area #2...
startup code area #2 is absent
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
detecting ffs/eeprom structure pass 2...
detect standard ffs/eeprom location pass #1...
detect standard ffs/eeprom offset pass #1...
ffs/eeprom record offset detected
detect standard ffs/eeprom data...
ffs/eeprom record size detected
ffs/eeprom layout detection complete
ffs/eeprom detected ok element #2
imei default found: 13579024681122
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: imei
error: error# 000000FF
error: flash write error: 004E0000:00002000
error: no any expected answer
error: can't write required area
Write Fail
Finished, time used: 232 sec
Old 12-15-2009, 16:06   #2 (permalink)
Member: 300690
Thanks Meter: 12
this is images
pleseeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Old 12-15-2009, 16:12   #3 (permalink)
Member: 300690
Thanks Meter: 12
Originally Posted by sartaj View Post
this is images
after this i did same the software shows.again and agin problem is same.
if we think phone is problem, i get this problem for all the mobiles have same model .
Old 12-15-2009, 23:41   #4 (permalink)
Member: 148515
Thanks Meter: 14,895
hello!
make read "gerneral information" on this phone, post log here
Old 12-19-2009, 09:39   #5 (permalink)
Member: 75838
Thanks Meter: 65
N958 pinout
Firts of all some models like n958,,p11,m99... Few models have a imei which displays with #06#.and another imei inside the firmware(#2imei).
Usually i do for #2imei with mode 1.but for these models when i use mode 1.software shows like in the image.
And when i use mode 2.than also software changes #1 imei.log is below
com5 [vcp0] selected
module v3.02
action: Imei
imei write method: Mode-2
imei write channel: Imei #2 for dual sim/mono cpu
model: Autodetect 6205-6227 nor
checking data, wait...
Phone should be switched off !
Press and hold power button now !
19200 autodetect
initializing [6225:8a03:8a00]...
Cpu: Mt6225
high speed boot on
status: Ff
connecting at 19200, wait...
Release power button now !
Hardware: Mt6225,e03
date: 2006.06.14
version: 1.0
version: E880_evtst.01.0_25s00
version: Even25_hw
0 done
44 byte(s) read
connection ok
0 done
44 byte(s) read
verification...
Verification done: 35392303084709
finished, time used: 25 sec
remove/install battery now !
And finally i used the option ""#1imei(defualt imei inside the firmware)than the log is
module v3.02
device: Autodetect 6205-6227 nor
Advanced flash detection enabled
action: "repair imei"
imei write channel: Imei #1 (default imei inside firmware)
====> boot ...
19200 fixed
connecting, wait...
Initializing [6225:8a03:8a00]...
Cpu: Mt6225
high speed boot on
status: Ff
release power button now !
Boot done
====> initialize ...
Detecting chip #00 in region #00...
Flash: Ec257e25082501:18e59f00000000
flash: Samsung amd/fujitsu std [d 0008x002000 00fex010000 0008x002000] 16mb
initialize done
====> set baud ...
115200
set baud done
====> initialize bootcode ...
Initialize bootcode done
====> check firmware integrity ...
Device parameters detection in progress...
it's time to stop: 18f09fe518f09fe518f09fe518f09fe518f09fe518f09fe5
Usb bootloader (chip) is absent
Search rom info finished
tcl-id is absent
new firmware detected (v.3.02, database date: 03.12.2009):
E880_my1mcf10_e880_gprs_mt6225_s00.01_2.bin
this firmware is missing in support area. If this phone is good and working:
- make "read full flash" operation
ver. Sw 1: E880_my1mcf10_e880_gprs_mt6225_s00.01_2.bin
ver. Sw 2: E880_my1mcf10.01.2, 00000000
ffs offset/size: 00e00000/001ff000
Standard ffs/eeprom offset detected: 00e00000
standard ffs/eeprom offset confirmed: 00e00000
Ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00e00000-00ffffff
Startup code area #2 is absent
Searching sec info#1...
Search sec info#1 finished
check firmware integrity done
====> check firmware content ...
Check firmware content done
====> backup required data ...
backup required data done
====> patch required data ...
Detecting ffs/eeprom structure pass 2...
Detect standard ffs/eeprom location pass #1...
Detect standard ffs/eeprom offset pass #1...
Ffs/eeprom record offset detected
Ffs/eeprom record size detected
patch required data done
====> special operation ...
Special operation done
====> write ...
flash: Ec257e25082501:18e59f00000000
write: Imei
error: Error# 000000ff
error: Flash write error: 004e0000:00002000
error: No any expected answer
error: Can't write required area
write fail
finished, time used: 232 sec
sir plz upload n958 pinout.
I have two set but ................
Old 12-19-2009, 12:38   #6 (permalink)
rameez_gsm's Avatar
Member: 327384
Sonork: 100.1605419
Thanks Meter: 312
Try to change imei mode try to mode3
Infinity slim box facing problem to find Spreadurm Cpu pinout bhogpurmail Infinity-Box 2 05-27-2008 21:04
Hello Infinity Team Problem To Spice S410.. Unlock... SAN INFOTECH Infinity-Box 2 12-20-2007 18:49
Challenging problem. Anyone game??? UUGuy CAR Electronics 2 10-27-2006 17:39
new to Infinity. A102 falsh problem UnlockBR Infinity-Box 2 01-09-2006 13:33
challenge!!! how to unlock blackberries mustangmoto BlackBerry (RIM) 15 02-20-2005 22:10
Page generated in 0.36823 seconds with 9 queries
