Old 10-04-2010, 18:13   #1 (permalink)
faizan15's Avatar
Member: 323959
Sonork: 100.1613721
Thanks Meter: 79
change cpu mtk6225
COM9 [VCP1] selected
module v3.09
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: repair security area
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:4C03:000D
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 98006F00000004:18E59F00000000
flash: AMD/Fujitsu std [T 0008x004000 00FFx020000] 32Mb
otp offset: 01FE0000
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
====> Set baud ...
460800
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 02000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is damaged, recalculation required
rom info detection finished
device-id: 2B0F4AF1
rom info ver: 04
sw version: SCUD25_07B_GEMINI_PCB01_GPRS_MT6225_S00.T502A_V05_ 2_FR.BIN
project-id: T502A_V05.2_FR, C1E0F1C3
code offset: 00000000
ffs offset/size [01]: 01E00000/00200000
TCL-ID is absent
detecting startup code area #2...
startup code area #2 is absent
startup code area #1 check...
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.2B0F4AF1.[SCUD25_07B_GEMINI_PCB01_GPRS_MT6225_S00.T502A_V05_ 2_FR.BIN_C3F1E0C1].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.2B0F4AF1._SCUD 25_07B_GEMINI_PCB01_GPRS_MT6225_S00.T502A_V05_2_FR .BIN_C3F1E0C1_.rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.2B0F4AF1.[SCUD25_07B_GEMINI_PCB01_GPRS_MT6225_S00.T502A_V05_ 2_FR.BIN_C3F1E0C1].rpl
rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.2B0F4AF1._SCUD25_07B_GEMINI_PCB01_GPRS_MT6225_S0 0.T502A_V05_2_FR.BIN_C3F1E0C1_.rpl
warning: unknown rom info structure: SCUD25_07B_GEMINI_PCB01_GPRS_MT6225_S00.T502A_V05_ 2_FR.BIN_C3F1E0C1
Unknown firmware detected (v.3.09, database date: ), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
error: startup code area #1 can't be fixed
sec info (fast) detection...
searching sec info#1...
search sec info#1 finished
error: incorrect ffs address range
Finished, time used: 1 min 50 sec
Remove/Install battery now !
repair security not support this phone plz help hoe to solve this problem
Old 10-04-2010, 19:15   #2 (permalink)
Member: 148515
Thanks Meter: 14,898
hello!
yes, this is unknown for our program firmware.
what problem you have with your phone?
Old 10-04-2010, 19:21   #3 (permalink)
faizan15's Avatar
Member: 323959
Sonork: 100.1613721
Thanks Meter: 79
this is dead phone or short i change mtk6225.. before cpu change phone not conect to software after change cpu phone conect but repair secuirty not support........
Old 10-04-2010, 19:55   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hi,
try to flash phone with firmware version similar to SCUD25_07B_GEMINI_PCB01_GPRS_MT6225_S00.T502A_V05_ 2_FR
I am not sure, but in most cases phone should be alive.
Old 10-05-2010, 18:17   #5 (permalink)
Member: 148515
hello!
read out firmware and post here, i will try to fix security inside file
Working IMEI changed phone? Barjo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 03-01-2015 11:49
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 21:09
Can anybody help me with solution to change 51/61/3210 IMEI? soff Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 02-08-2011 15:28
Change Bin-file in Nokia..possible?? BiG Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 11-20-1999 16:56
ESN Change OGOMEZ Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-22-1999 00:56
Page generated in 0.32269 seconds with 8 queries
