04-09-2007, 16:21 | #1 (permalink) |
Freak Poster Join Date: Sep 2003 Location: onFrontOfMyComputer Age: 40
Member: 40460 Status: Offline Thanks Meter: 18 | G50 imei repair Device: Panasonic G50,G51 Checking data, wait... Action: Imei repair Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 98005700000004 flash: 8CE59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... Check space Done Check parameters... file saved: backup_error_log_20070409-181309.00L.bin Err: Imei not found or damaged Err: Operation aborted Finished Remove/Install battery now ! Time used: 14 sec --------------------------------------------------- What is problem?? if i must flash eeprom, where can i find eprom file. because support files for g50 are not have eprom file.. only frimware, map and language pack have.. Thanks. |
06-19-2007, 21:27 | #5 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Sao Paulo - BRAZIL Age: 49
Member: 26751 Status: Offline Thanks Meter: 2 | Just got a G51M with IMEI 35042103-0000600. Here goes log about fix tentative: COM1 selected Device: Panasonic-G50,G51 Checking data, wait... Action: Unlock Boot... Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 98005700000004 flash: 8CE59F00000000 flash: 98005700000004 flash: 8CE59F00000000 Boot Done Set baud... 115200 Set baud Done Check Flash... Check Flash Done Check space... file saved: backup_eeprom_unlock-1_20070619-172301.00E.bin Check space Done Check parameters... Check parameters Done Format file system... area-01... area requested/selected: 02/02 Format file system Done Write... Preparing... area requested/selected: 02/02 Write Done Finished Remove/Install battery now ! Time used: 29 sec Is it damaged flash chip too?? Tks in advance, UnlockBR |
06-20-2007, 11:35 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @UnlockBR it can be that flash chip damaged or in phone was installed new flash chip. In case of replaced flash chip we can't repair imei yet. |
SonyEricsson W800 - Unlock/IMEI Change/IMEI Repair - Which Cable? | gaz_0001 | Sony Ericsson | 3 | 08-26-2006 17:00 |
Samsung E720 - Unlock/IMEI Repair/IMEI change - which cable?? | gaz_0001 | Trident/AGERE Platform | 2 | 06-22-2006 18:13 |
804ss/z540 The IMEI repair.Bluetooth repair | liufeifei | QUALCOMM Models (3G) | 1 | 05-17-2006 16:10 |
G50 imei change | starking chou | Panasonic | 2 | 04-04-2004 13:54 |
P2K Ultimate Box, Unlocking, IMEI Repair, Chinese flash repair and more! | VictorGSM | Main Sales Section | 0 | 07-31-2002 04:36 |
